B18B1 Head work
Old Apr 13, 2002 | 08:59 AM
legendboy's Avatar
Default B18B1 Head work
I will be sending my head out next week and I would like some feedback on what I should get done for more power. Daily driver and the ocational race I think that I want the most power on the top end. Any ideas on cams? Valves & springs? Headgasket? I would like to raise the c/r too.
[Modified by legendboy, 11:01 AM 4/13/2002]
[Modified by legendboy, 12:14 PM 4/13/2002]
Old Apr 13, 2002 | 09:16 AM
Armaan's Avatar
Default Re: B18B1 Head work (legendboy)
One piece of advice: GO TO PORTFLOW. Look what they did to my B18A cylinder head:
http://www.overboost.com/story.asp?id=463
Old Apr 13, 2002 | 01:50 PM
GSG2's Avatar
before sending the head u should make up your mind on what cams to use - so that the porter can P/P the head based on the cam profiles.
PORTFLOW
Raising the compression by shaving the head is wasting the head especially if it's gonna be port and polished and getting a valve job. just put high compression pistons. ( costly though )
on cams, crower 403 LS cams are quite good. making power on low or high rpms can depend on the cam gear settings but the P/P head will surely help. do some more reading about other ppl setups to compare and contrast the power made and the cost of their set ups. ( i.e. FI or lsvtec)
i heard that 404 cams are not that good on stock LS compression (too low) ... someone pls. correct me if i'm wrong.
HTH
josh green
Jan 20, 2010 02:52 PM
u_tal
Dec 31, 2009 11:23 AM
chris2000
17
Dec 7, 2006 12:50 PM
