b18b1 compression
Old Feb 19, 2012 | 02:34 PM
1994turbocivic's Avatar
Default b18b1 compression
i rebuilt a b18b1 block and head, honed, decked, pressure tested. new supertech valve guides and seals, npr rings, acl race bearings, oem oil pump, gates racing water pump and t-belt.
im slowly buring oil, i think i didnt seat rings rite. idk
my concern is my compression, all 4cyl have and hold 205psi when warm
few of my friends stock OG miles engines ive tested, come out to 170-180
Old Feb 19, 2012 | 02:44 PM
Dc4LsTeG's Avatar
EK9
Default Re: b18b1 compression
Is it smoking? How much oil are you burning? Those numbers look good
Old Feb 19, 2012 | 02:47 PM
DirtyDA9's Avatar
Which angles did you have the rings gaps at? You probably have some of the gaps lined up with the wrist-pin, or have the ring gaps lined up with each other.
Old Feb 19, 2012 | 03:00 PM
it burns about 1qt a week lol... yea i found that out, about the rings being aligned away from the load sides. i aligned them up together.
would burning oil affect the comp results?
Old Feb 19, 2012 | 03:01 PM
Dc4LsTeG's Avatar
EK9
You aligned the gaps together?that's your problem
Old Feb 19, 2012 | 03:07 PM
im fine for now, rite? just keep an eye on oil level. it only smokes on really cold starts, and reving hard past 5k
Old Feb 19, 2012 | 03:12 PM
Dc4LsTeG's Avatar
EK9
I wouldn't keep driving it if its burning a quart a week. Id pull it and just re do the rings before anything gets messed up
Old Feb 19, 2012 | 03:17 PM
i drive 120 miles a day, five days a week. plus bout 10-15 miles on weekend... that y its 1qt a week.
Old Feb 19, 2012 | 03:19 PM
also if i redo the rings, would i need to hone it again? i know it best, thanks for the feedback
Old Feb 19, 2012 | 03:32 PM
DirtyDA9's Avatar
Yea the rings being aligned is the problem. Do a compression test, then a wet comp. test, then a leakdown test. Also did you gap the rings before putting them on the pistons?
Old Feb 19, 2012 | 03:36 PM
DirtyDA9's Avatar
And you should be able to reuse those rings. And you shouldn't need to rehone it either.
Old Feb 19, 2012 | 03:40 PM
dry comp- 205psi, wet comp- 205-207psi, both on running temp engine.
didnt gap rings, is it a must?
this is my second build -1st i was being tutored, -2nd this my second, -3rd work in process
Old Feb 19, 2012 | 05:40 PM
DirtyDA9's Avatar
Well whoever tutored you on the first one doesn't know what they are doing if they didn't set the ring gaps, and show you how to align the gaps.
And yes, ring gaps are kind of a big deal...
Old Feb 19, 2012 | 06:27 PM
he did align them but didnt tell me it had to be done. thanks alot, i will definitely get to work on gapping them, aligning them correct.
Old Feb 19, 2012 | 07:32 PM
DirtyDA9's Avatar
Make sure you purchase the proper ring gapping tool/grinding wheel.
Check this out so you get an idea of how the ring gaps are supposed to be aligned, this is just an example as it is not for hondas, you will want to purchase a helms manual before you try to gap the rings and align the gaps on the pistons.
http://www.google.com/imgres?q=pisto...=0CMUGEK0DMLkB
SiR Inspired ED7
15
Jul 31, 2007 05:19 PM
Sassafrass
20
Jul 18, 2006 07:06 PM
red teg
Oct 9, 2005 03:33 PM
Old_Honda
Apr 5, 2005 08:25 PM
