B18b head on b16a2 block... NEED HELP
Old Aug 27, 2024 | 10:55 PM
That-90teggy's Avatar
Default B18b head on b16a2 block... NEED HELP
I have just recently purchased a 1990 integra and the seller put in a b16a2 block with a b18b head, soon to find out there is oil leaking from the headgasket. So i take the head off and the head gasket seems fine. Im starting to think that maybe a b18 head wont work on a b16 block... please help?
Old Aug 28, 2024 | 02:31 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: B18b head on b16a2 block... NEED HELP
No, a non Vtec B18 head won't work on a B16 or any B series Vtec block.
Only combo that works is a B16 head or any B series Vtec head on a B18 or B20 non Vtec block (LSVTEC). (B20VTEC)
Old Aug 28, 2024 | 08:19 AM
Could that also be the reason its leaking oil?
Old Aug 28, 2024 | 11:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, VTEC "B" series engine blocks have an oil passage near the right rear corner of the block that feeds the VTEC circuit... a non-VTEC cylinder head, as well as the matching head gasket, does not cover this oil feed passage. Thus, you have a significant oil leak when the engine is running. Other than somehow plugging the oil feed passage in the block before installing the cylinder head... I do not know how to make a non-VTEC head work on a VTEC block. Even if you sealed this passage off... the next problem is going to be timing belt choice. The B16A belt may fit using a non-VTEC oil pump, but I have never tried it.
This combination is just a bad idea. I suggest you wrangle up either a VTEC head OR a non-VTEC short block and make a proper complete engine out of half of what you got.
Old Aug 29, 2024 | 12:00 AM
Thank you man, i was getting discourage and worried cause im only 17 and this is my first project lol... I already have a b18a block and head so its just shop time for the next few weeks lol
eglslsd
Jun 26, 2007 02:21 PM
tougeEGsies
Apr 4, 2006 04:26 PM
Erik_Pb_Foot
Jan 27, 2004 09:42 AM
the jdmchop
Aug 5, 2003 10:50 AM
enabi
Sep 29, 2002 09:33 PM
