B18A Question
Old Sep 10, 2008 | 07:47 PM
SIRIUS VTEC's Avatar
Default B18A Question
Im in the process of learning about motors and what not, quick question..
I have rod knock on my B18A usdm 93 integra LS
I found a b18a out of a 1990
My question, is there any difference between a 90' LS motor and a 93 LS Motor? any real significant difference?
Old Sep 10, 2008 | 08:19 PM
BMXman's Avatar
Default Re: B18A Question (SIRIUS VTEC)
As far as I know they both have b18a engines so everything should be the same.
Old Sep 11, 2008 | 03:55 AM
gtec8285's Avatar
yea theres a difference the 90-91 i believe is obd0 and 92-93 is obd1
Old Sep 11, 2008 | 11:07 AM
BMXman's Avatar
Default Re: B18A Question (gtec8285)
oh yeah right..but I think he's more concerned about rods.
Old Sep 11, 2008 | 02:03 PM
wakaranai's Avatar
Default Re: B18A Question (BMXman)
Engines=same
Electronics=different.
b18a vs b18b=different.
Old Mar 3, 2009 | 07:50 AM
Gurajit's Avatar
New User
Originally Posted by wakaranai
Engines=same
it's not a a/b difference though. If the 90' engine is all you can than I guess that's fine. You will have less HP and torque. Also you'll have to use your intake manifold (fuel rail too) and distributor. Are you sure it's a thrown rod? The easiest swap will be a 92-95' engine, so a b18a1 from 92-93 or a b18b from 94-95. You'll have 2 more HP with the b18b (woo) and a younger engine and won't have to convert to a different obd.
Old Mar 3, 2009 | 08:36 AM
94_Teggy's Avatar
just swap out the blocks! no need to do the whole engine!!
Old Mar 3, 2009 | 09:26 AM
JDMDALOUIE's Avatar
Doesn't the B18 on 90-91 have 10 less HP than the 92+ B18?
Old Mar 3, 2009 | 12:51 PM
lexrob's Avatar
the 92-93 cams are "slightly" bigger.. and the fact that its obd1 thats the power increase so if you just do the block it will be exactly the same.. not shur if the head itself excluding cams has any differences
95civicproject
Feb 22, 2012 05:39 AM
hotinteggy
Feb 28, 2007 12:37 PM
Excelerate
Dec 22, 2005 12:38 PM
DavidTurbo
Mar 25, 2003 06:12 PM
elmalouno
Jan 26, 2003 10:24 PM
