B17A Computer running B16A1????
Will a B17A1 USD ECU run a B16A1 Motor? I was wondering because the JDM B16A Compuer has a speed limiter. If I swaped ECU's this might fix the problem.
The B17 ecu is a P61 and it is OBD1.
If you use it with a 1st gen B16 you'll have to convert it to OBD1.
Probably cheaper to reprogram the ecu you have.
