b16 obd1 help!
Old Apr 16, 2006 | 11:30 PM
DA90's Avatar
Default b16 obd1 help!
just got me a 1990 integra with b16 obd1 motor stock.. it grinds when i shift to 3rd gear.. what should i do? .. please help
Old Apr 17, 2006 | 12:23 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: b16 obd1 help! (DA90)
just skip third, ... Jk
it only grinds in third?
Old Apr 17, 2006 | 03:39 AM
JDMPheens's Avatar
synchros, try gassin it between 2nd and 3rd and see if it goes away most likely its ur synchros. hondas are notorious for this.
Old Apr 17, 2006 | 06:56 PM
Sam92Teg's Avatar
First thing you can do is check your MTF level and condition.
Then check the clutch adjustment.
If these are fine, then the tranny internals, ie syncros are starting to lose their ability to rev match the gears, assuming there isn't operator error involved.
Old Apr 17, 2006 | 07:18 PM
Wayne_Curr's Avatar
Default Re: b16 obd1 help! (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">First thing you can do is check your MTF level and condition.
If these are fine, then the tranny internals, ie syncros are starting to lose their ability to rev match the gears, assuming there isn't operator error involved.</TD></TR></TABLE>
hehe, assuming that of course
When was the last time the MTF was changed? I hadn't changed mine in prolly 40k til this weekend, now my mysterious random second gear grind seems to be gone. That old gear lube was watery as hell. New stuf thick like syrup
Old Apr 18, 2006 | 01:49 AM
DA90's Avatar
Default Re: (JDMPheens)
yep only grinds on third.
Old Apr 18, 2006 | 01:50 AM
DA90's Avatar
Default Re: (DA90)
i dont know when it was changed.. how do i check it?..
Old Apr 18, 2006 | 04:41 PM
Sam92Teg's Avatar
Default Re: (DA90)
If you pull the passenger side wheel, then look at the passenger side of the tranny case, you will see two large bolts, one lower and one higher. The lower bolt is the drain bolt, the higher is the fill bolt. You can pull the higher bolt and hopefully some oil will slowly spill out because the oil should be up to that bolt. If it doesn't, stick your finger in there and see how low it is.
I recommend buying 3 quarts of Honda MTF, a funnel, and a two foot section of hose. Use a drain pan and drain the old MTF out of the lower bolt, then retighten. Then use the funnel and hose from up top, put the other end of the hose in the fill bolt hole. Should take around 2.3/2.4 quarts.
Old Apr 18, 2006 | 11:19 PM
DA90's Avatar
Default Re: (Sam92Teg)
thanks im going to do this as soon as possible
Old Apr 18, 2006 | 11:55 PM
Wookie384's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">If you pull the passenger side wheel, then look at the passenger side of the tranny case, you will see two large bolts, one lower and one higher. The lower bolt is the drain bolt, the higher is the fill bolt. You can pull the higher bolt and hopefully some oil will slowly spill out because the oil should be up to that bolt. If it doesn't, stick your finger in there and see how low it is.
I recommend buying 3 quarts of Honda MTF, a funnel, and a two foot section of hose. Use a drain pan and drain the old MTF out of the lower bolt, then retighten. Then use the funnel and hose from up top, put the other end of the hose in the fill bolt hole. Should take around 2.3/2.4 quarts. </TD></TR></TABLE>
Just make sure you get the filler plug open before you drain the fluid. Just a trick I do just in case. You don't wanna get stuck with no trans. fluid and you cant fill it up again.
jonezen1
Aug 10, 2007 12:37 AM
Lucky-13
11
Mar 11, 2007 04:10 PM
Integra99
May 26, 2006 10:34 AM
B16X
Aug 11, 2004 06:35 AM
BeeResp0nsible
Aug 21, 2002 02:36 PM
