Automatic cluster in an manual?
Old Dec 16, 2002 | 12:41 PM
B2FiNiTY's Avatar
Default Automatic cluster in an manual?
Does the cluster from an automatic plug and play for a manual integra?
Old Dec 16, 2002 | 12:54 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Automatic cluster in an manual? (B2FiNiTY)
I would have to say yes.....but I'm not 100% sure . My Integra was an automatic, and when I did the 5-speed conversion, I didn't have to modify the cluster area at all. The only thing I did was take out the light bulbs for the P. N, R, etc.
Old Dec 16, 2002 | 03:00 PM
Davanca's Avatar
Default Re: Automatic cluster in an manual? (shamoo)
He's right you don't have to modify the cluster for fitment. The problem your going to run into is on the picture, i highlighted the yellow tab. (this is a auto cluster) That yellow tab is for the fuel gauge. Auto have an additional harness wire for the fuel gauge. Where the Manual clusters don't have that yellow tab.The manual cluster reads the fuel righ toff of the tab that you connect for the MPH.
Old Dec 16, 2002 | 03:55 PM
B2FiNiTY's Avatar
Default Re: Automatic cluster in an manual? (davanca24)
I wonder if I can buy the cluster and just swap the guages then. Anyone have pics of the automatic cluster?
Old Dec 16, 2002 | 04:04 PM
-BlueGSR-'s Avatar
Just wondering...why do you want to do this?....sleeper look maybe? lol...
Old Dec 16, 2002 | 04:11 PM
B2FiNiTY's Avatar
Default Re: Automatic cluster in an manual? (GS-ssbp-R)
Basically... I need to go lowkey for about 2 years. Moving to a ghetto area that is high risk.
Old Dec 16, 2002 | 07:10 PM
EndlessGarageEG6's Avatar
That yellow clip my freind is the SRS clip. I have mine unpluged for the Sparco steering wheel.
Auto cluster goes right in with no mods needed
But why would you want to do that?
Old Dec 16, 2002 | 07:21 PM
Davanca's Avatar
Default Re: Automatic cluster in an manual? (CRintegreX)
Hey is your fuel gauge working. The reason i ask is because when i had an auto teg, i slapped in the indiglo dash, when i put my cluster back and i forgot to connect that yellow wire. My fuel gauge went all the way down to E, when i started the car. I had to set the needle again, pu twhen i plugged it in it was working.
Old Dec 16, 2002 | 10:17 PM
B2FiNiTY's Avatar
I finally got the problem solved. I believe it will just plug in. The yellow plug is indeed for the srs.
If you have a 00-01 Integra you need the same year cluster. If you have something from before they will work. I tried a 96 cluster in an 01 before and it didn't work because the fuel and the temp were all messed up.
Old Dec 16, 2002 | 10:19 PM
correctemondo!
Old Dec 17, 2002 | 03:56 AM
Ricky Rojales's Avatar
How do you go sleeper on a stick in your center console though?
Hat?
Old Dec 17, 2002 | 11:05 AM
B2FiNiTY's Avatar
Default Re: Automatic cluster in an manual? (Ralphie)
Hat?
It's the same idea with those people with automatics that have "manual like" shift *****
Old Dec 17, 2002 | 09:04 PM
Paste's Avatar
Loved
heh, i wouldnt screw with the gauges though, it is illegal
[Modified by paste, 11:05 PM 12/17/2002]
Old Dec 18, 2002 | 02:28 AM
IntEGNYC's Avatar
How about a paper bag from your 40.
Old Dec 18, 2002 | 05:23 AM
fEEsh's Avatar
I know how that goes. I get shoes stolen from my garage!
Old Dec 18, 2002 | 06:20 AM
boostdGS's Avatar
no...
I have a 98 gs 5 speed, and it definantly has that yellow clip there. Always has been 5 speed, always will be.
cheers
Old Dec 18, 2002 | 09:26 AM
darrinbrewer's Avatar
Default Re: Automatic cluster in an manual? (boostdGS)
i got a 94 5sp gsr -i got the yellow clip there too. hint: when installing indiglo guages--don't use stinger spray adhesive -doesn't work well -use super glue
Old Dec 18, 2002 | 09:51 AM
B2FiNiTY's Avatar
Default Re: Automatic cluster in an manual? (darrinbrewer)
The yellow plug has already been cleared up. It is for the srs.
tyler100
Feb 5, 2008 07:31 PM
dirtycolombian
Jun 10, 2007 09:27 PM
projsectEF
Sep 30, 2006 04:30 AM
AzntaggeR
May 21, 2005 05:47 PM
endlessdv
Apr 13, 2004 02:46 AM
