Atomsphere Pressure CEL light? help!!
Old May 3, 2004 | 07:02 PM
JdmIntegra98's Avatar
Default Atomsphere Pressure CEL light? help!!
I do not have forced induction.... just intake and header.... i recenctly took off my skunk2 intake mani.. and had the orginal one put back on (a few months ago)... would this have anything to do with it... im am pretty sure that it is install correctly... could this be a vaccum leak? if anything else comes to mind that has nothing to do with the mani.. let me know too thanks! also when i hit 6000 rpms... around there it feels like i am hitting fuel cutt off and it bounces around...
i have a gsr 98
Old May 4, 2004 | 05:14 AM
JimBlake's Avatar
Default Re: Atomsphere Pressure CEL light? help!! (JdmIntegra98)
Do you mean it's throwing code 13 (barometric pressure sensor)? Some years that's built into the ECU, some years you can replace the sensor. (I don't know about 98.)
If it's code 3 (manifold pressure sensor) that's a different story...
Old May 4, 2004 | 11:58 AM
it is code 13.. for a integra that is atomsphere pressure im pretty sure.... i was told that was located in the Map sensor..??? and what does it mean if that light comes on?
Old May 4, 2004 | 12:16 PM
integranator's Avatar
Default Re: (JdmIntegra98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmIntegra98 &raquo;</TD></TR><TR><TD CLASS="quote">it is code 13.. for a integra that is atomsphere pressure im pretty sure.... i was told that was located in the Map sensor..??? and what does it mean if that light comes on?</TD></TR></TABLE>
sensor might have been broken during install.
the choppy feeling up top is where for some reason the sensor is finding pos. pressure, much like a boosted car-- so it'll go into limp mode-- check that sensor.
Old May 5, 2004 | 09:33 AM
so i should check the map sensor???
DA_zooooms
Aug 10, 2009 09:08 PM
b18c1vtecdc2
Sep 28, 2008 11:55 AM
2000civicsi
Oct 15, 2005 07:09 PM
THE FUCATYPR HATCH
Jan 27, 2005 09:17 PM
JdmIntegra98
May 5, 2004 09:34 AM
