Apexi WS2 Install problem
So I bought this exhaust, installed it, the axleback portion is rubbing the bumper, the mid pipe is resting against the floor pan causing a vibration in the whole car. What's the deal? Does anyone have any ideas what the problem could be?
Sorry I referred to the wrong part the midpipe does sag a bit. It's the b pipe that is rubbing the side of the exhaust "tunnel". Also the canister does notappear to be level when looking at it from the rear of the car and the tip is not lined up with the notch in the bumper. I will post pics up tomorrow so you can see what I mean. Thanks
Here are some pics, you will notice the canister offset from the notch in the bumper, you will also notice a piece of rubber in between the b pipe and the floor pan, I put it there to keep the vibration down.
I also had to remove my stock sway bar in order for the exhaust to clear???
Let me know your thoughts on what I can do to get this straightened out.
Thanks
Thanks
Hey 3rd picture down said a lot for me. Do this. Measure center of the resinator out to each exhaust hanger prong. And compare the two side. It seems to me as if the driver side hanger is out further than the passanger.
But that can be due to angle also. Take a picture from the front of the car, I want to try and get a idea of the header in refferance to the oil pan. Something up front is forcing the exhaust over. Are you still using the spring loaded bolts to mount the header to the cat? I cant tell by the picture but it dosnt look like it.
I will get another pic of it from the front of the car, and post it soon.
Does anyone have under car pics of their ws2 install on an integra?
Thanks ASIAN
I contacted Apexi today, they do not have any of the WS2's in stock, they are going to ship me a NOIR replacement. Lets hope this one installs properly, I will keep you posted. Thanks for your help.
nicolaselias
Sep 29, 2010 08:24 PM
igo4bmx
11
Oct 6, 2004 05:52 PM
for apex'i giving you a replacement!
