Any way to replace wheel stud??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 »</TD></TR><TR><TD CLASS="quote">Is there any way i can replace the wheel stud without having to pull the whole hub off?</TD></TR></TABLE>
not that Im aware of...But if you do find a way post it
nope i did this a while back but didnt work so i got a puller and pulled the hub to replace it unless its the rear cause there is just enough room to get the new stud in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 »</TD></TR><TR><TD CLASS="quote">My dealer quoted me 430 to do that, they said you have to replace the bearings after because pulling out the stud bends the bearings.</TD></TR></TABLE>
Uhh it should only cost $35 at any local tire shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 »</TD></TR><TR><TD CLASS="quote">They told me I have to replace the whole hub assembly. 2000 Acura Integra GSR</TD></TR></TABLE>
Oh ok that makes sense . 4x wheels studs @ 35$ apiece along with $300 wheel bearing R&R adds up to that much. Thanks for clearing that up.
you have to press out the front hub to get the studs out.......and once you press out the hub it pretty much ***** up the wheel bearing..........its a real pain in the ***.
Hulk_EJ8
Nov 15, 2005 01:59 AM
Tyson
Feb 11, 2004 01:11 AM
