antenna problems
Old Feb 17, 2006 | 10:11 AM
teggsr925's Avatar
Default antenna problems
my antenna wont go down, the radio still works and the motor for the antena still works, wats the problem, is it jus cuz its cold out
Old Feb 17, 2006 | 10:55 AM
teggsr925's Avatar
Default Re: antenna problems (teggsr925)
any1 wit some info?
Old Feb 17, 2006 | 11:41 AM
DC2 Mang's Avatar
proabably got rusted inside, just hit it down carefully, or you can go buy a new antenna at almost any auto parts store
Old Feb 17, 2006 | 11:51 AM
.one lane's Avatar
.likes trains
lub it up?
Old Feb 17, 2006 | 11:53 AM
Rcp's Avatar
Rcp
It might be your stereo.. I used to have an AIWA deck and it never sent a signal to my antenna to go down when the radio is off or not in use.
Old Feb 17, 2006 | 11:54 AM
Tornadom's Avatar
Clean the antenna really well. A little Mother's mag & aluminum Polish should help to smooth things out, and if it doesn't make it go down at least you will have one nice looking antenna.
Old Feb 17, 2006 | 01:57 PM
95SE 4DR's Avatar
My antenna wasn't able to go down all the way automatically. I always used to have to push it down.
So what I did was I sprayed it with WD-40 while it was up. Just make sure you don't get it on your paint. If you do just make sure you wipe it down dry. Should go up and down a lot smoother after that.
Old Feb 17, 2006 | 01:59 PM
Dc2 David's Avatar
i belive there was a problem with the antennas on the integras, mine just recently stopped working and decided to do the s2k conversion, waiting on my antenna from Len
Old Feb 18, 2006 | 01:35 PM
teggsr925's Avatar
Default Re: antenna problems (Tornadom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">Clean the antenna really well. A little Mother's mag & aluminum Polish should help to smooth things out, and if it doesn't make it go down at least you will have one nice looking antenna.</TD></TR></TABLE>
it doesnt go down at all
Old Feb 18, 2006 | 02:20 PM
Tornadom's Avatar
Well, there is still nothing wrong with a clean and shiny antenna.
Old Feb 18, 2006 | 04:54 PM
teggsr925's Avatar
bump for more info
ima try the wd40 though
Old Feb 18, 2006 | 04:59 PM
jomama's Avatar
i've had the same problem... and i also have the same problem on accords my family's had in the past. i'm so lazy about getting it fixed... but you should look into antenna masts or if you want to go all out and go the OEM route still, just get a replacement motor with mast... others have gone the s2k route as noted earlier
Old Feb 18, 2006 | 05:03 PM
teggsr925's Avatar
i tried the wd40 any it moves but the motor runs when i turn the radio on and off but the antenna still wont go down plz some info, might jus have to got s2k conversion
Old Feb 19, 2006 | 07:06 AM
teggsr925's Avatar
bump
Old Feb 20, 2006 | 03:41 PM
teggsr925's Avatar
bump for more help
Old Feb 20, 2006 | 04:26 PM
gixer00's Avatar
WELL YOUR ANTENNA MAST HAS A PLASTIC TRACK THAT GOES INTO THE MOTOR AND SOMETIMES THAT PLASTIC TRACK BREAKS AND YOU HAVE TO GET A NEW MAST
Old Feb 20, 2006 | 04:38 PM
SlamminS85's Avatar
Default Re: (gixer00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gixer00 &raquo;</TD></TR><TR><TD CLASS="quote">WELL YOUR ANTENNA MAST HAS A PLASTIC TRACK THAT GOES INTO THE MOTOR AND SOMETIMES THAT PLASTIC TRACK BREAKS AND YOU HAVE TO GET A NEW MAST</TD></TR></TABLE>
exactly, its simple, unscrew it, and remove the antenna, it pulls out fairly easily. Then get a mast replacement at most auto parts stores for like 6 bucks, and tell them that they have it because more than likely they will try to sell you the entire motor with mast for like 5 bucks. Then just insert the new mast the way it was.
I have done this twice BTW, so im pretty good at it, and its really simple, you dont even have to get in the car to do it.
Also about antennas... why dont you people have quality enouigh stereos to get the antenna to be down when you are playing CD's or Tapes.. in my opinion there is nothing more stupid looking than an antenna sticking off a car... my alpine automatically does that, but you also could install a simple switch to keep it down when listening to CD's
skinnyshugg's Avatar
i dissconeccted my broken antenna cause theres nothing good on the radio neway lol
Old Feb 20, 2006 | 04:58 PM
Ghettokracker71's Avatar
Yeah my antenna won't go up anymore. Back when I worked circuitcity roadshop,we saw alot of integras with busted *** antennas
Old Feb 20, 2006 | 11:53 PM
twenty20hindsight's Avatar
And here I thought I was going to get a cool title
get a s2k antenna!
Old Feb 21, 2006 | 12:58 AM
TurdBlown Teg's Avatar
Default Re: (skinnyshugg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinnyshugg &raquo;</TD></TR><TR><TD CLASS="quote">i dissconeccted my broken antenna cause theres nothing good on the radio neway lol </TD></TR></TABLE>
i hear you on that. mine isnt broken just frozen soo its pushed down and unpluged. no use for the radio when i have my ipod rigged to it.
fergs96integra
Jan 11, 2006 03:06 PM
Modifiyem
Feb 5, 2004 06:03 PM
CrazyModGSR
Jan 13, 2004 12:36 PM
TypeRod
Nov 29, 2002 08:45 AM
AndrewJ
Aug 31, 2002 11:31 PM
