Alternator?
Old Oct 22, 2005 | 07:18 AM
shiux's Avatar
Default Alternator?
how do you change (take out/put in) the alternator for a 1990 integra LS?
Old Oct 22, 2005 | 09:09 AM
Sack Master's Avatar
Default Re: Alternator? (shiux)
You'll probably have to remove the axle. But aside from that. Unplug it and unbolt it. Pretty easy to do.
Old Oct 22, 2005 | 09:30 AM
Muckman's Avatar
Moderator in Chief
Actually you can get away without removing the axle. Remove the bolts holding the bearing support on the intermediate shaft and flip it down. It may slightly hit the steering rack and but theres enough play in the drive shaft to get clearance.
Then you can drop the alternator from the bottom. It takes some planning to orient the alternator so it has the smallest cross section to maneuver it between the steering rack and drive shaft. It takes alot of jiggling and twisting but it can be done. Shouldn't need any pry bars or to remove anything else.
Ive done it twice this way in my 91 LS and I can replace the alt in about 30-45 mins.
91akira
Aug 15, 2017 05:12 PM
mooner23
Jun 8, 2011 05:13 PM
tkewtn
Oct 31, 2007 08:10 AM
RoboTeg
Aug 16, 2005 05:54 PM
Layziebtnh055
May 3, 2004 12:07 PM
