Alternate jacking points?
Old Jul 11, 2005 | 06:56 PM
beanbag's Avatar
Default Alternate jacking points?
Hello,
I already know about the front, side, and rear jacking points. My question is what other points can you use to jack up the car? Typically, I only want to raise up one corner of the car, and the put a jackstand under the standard jacking points. Can I use:
lower control arms, directly below where the shock connects?
Points slightly in front or behind the side jacking points? (so I can fit jackstands there)
Any other places?
Old Jul 11, 2005 | 07:09 PM
migs's Avatar
Default Re: Alternate jacking points? (beanbag)
Are you using a floor jack? If so, if you have a low enough jack, you can jack up the vehicle from the rear tow hook and front core cupport.
If you are using a 2 post system with scissors that go underneath the vehicle, you can use the "feet" to pickup from the frame rails.
Old Jul 11, 2005 | 07:17 PM
TrueUntilDeath.com's Avatar
Default Re: Alternate jacking points? (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Are you using a floor jack? If so, if you have a low enough jack, you can jack up the vehicle from the rear tow hook and front core cupport.
If you are using a 2 post system with scissors that go underneath the vehicle, you can use the "feet" to pickup from the frame rails. </TD></TR></TABLE>
couldnt have said it better.
you can also use the front tow hooks on each side
danno33
May 25, 2008 03:23 PM
babzog
Honda Civic (2001 - 2005)
May 19, 2008 05:01 PM
circlecivic
Jan 20, 2006 10:19 AM
Touch
Jun 27, 2005 01:40 PM
JL 74
May 3, 2002 09:26 AM
