AEM Filter
Old Feb 28, 2003 | 03:34 AM
chopsgsr's Avatar
Default AEM Filter
Does anybody know of a way to replace the AEM CAI filter without removing the bumper? That bumper is a pain when when you don't have the right tools.
Old Feb 28, 2003 | 03:36 AM
tC_Dragon's Avatar
Default Re: AEM Filter (chopsgsr)
yea, i did mine last weekend, just raise ur car, then undo the fender well plastic trim stuff, its held on by a couple screws, and its as easy as that.... you may have to bend the hose end of the filter, but its rubber so no big deal.
Old Feb 28, 2003 | 05:45 AM
PM-Performance's Avatar
Default Re: AEM Filter (pdcdragon)
thats the way i did mine when i had em . takes only a few minutes.
i have gotten soo good at taking my front clip off thoguh, i can take that off in the same amount of time to get that flap down
Old Feb 28, 2003 | 06:03 AM
Rory Breaker's Avatar
Just reach in their with a screwdriver, undo the clamp and pop the SOB out.
Old Feb 28, 2003 | 07:52 AM
98type_r's Avatar
New User
what tools? it doesn't require anything special to remove the bumper...
do it a couple more times and you'll have it down to a science
Old Feb 28, 2003 | 08:17 AM
Default Re: AEM Filter (tie par)
the bumper is
2 10 mils to hold the bumper at the bottom to the frame
2 10 mils on each side of the car by the fenders under the hood
like 8 phillips screws for that track accros the top where the hood latch is
2 phillips screws that holds the liner to the front end ( the flaps)
take out htwe turn signals
and 1 phillips in each fender well under neath the fender line , pop out the one pop screw in each fender line to get that 1 screw inside the line and from there pop the front end off the car, its kinda like snappped inplace, so will need a littl tug on it .
damn can you tell ive done thattoo many times. sounds like alot, but i can do it in like 2 minutes, i got it down to a science.
Old Feb 28, 2003 | 08:38 AM
tC_Dragon's Avatar
Default Re: AEM Filter (itr206)
you dont need to take off the bumper!! jus undo the fenderwell trim from underneath like i said!
Old Feb 28, 2003 | 09:10 AM
MR. ARIZONA's Avatar
YEa, I didn't even take off my bumper when I installed mine. Just turn the wheel all the way to the left OR right to get the tire outta the way and pop of those screws on the fenderwall. Easy ****
Old Feb 28, 2003 | 09:36 AM
DR3AM's Avatar
Are you actually referring to the fender lining in the wheel well or just the plastic lining underneath the car?
Old Feb 28, 2003 | 11:16 AM
tC_Dragon's Avatar
Default Re: AEM Filter (Gizzzer98)
directly underneath the filter, is only the plastic of the fender liner extended forward, so you jus unscrew that.
Old Feb 28, 2003 | 01:27 PM
DR3AM's Avatar
Cool...thanks!!!
Old Feb 28, 2003 | 01:38 PM
jeebusm3's Avatar
are you actually gonna replace the filter, rather than clean it? Mine has a K&N don't they all?
Old Feb 28, 2003 | 01:41 PM
98Psi ITR's Avatar
Default Re: AEM Filter (gtravsr)
We stopped using K&N's filters a while ago.
Old Feb 28, 2003 | 07:45 PM
jeebusm3's Avatar
Default Re: AEM Filter (98Psi ITR)
who's we?
AnAccordIsForever
Mar 12, 2008 02:33 PM
killyourscene
Honda Civic (2006 - 2015)
10
Feb 24, 2008 12:03 PM
myuglycivic
Aug 17, 2005 06:56 PM
eluder33
Aug 17, 2004 09:05 PM
hYpE-R-29
Apr 7, 2002 03:21 PM
