AC question..
Old May 11, 2005 | 11:03 AM
mingbling96's Avatar
Default AC question..
my AC have not been working for a while. i'm pretty sure its the compressor. If I buy a new compressor, receiver/dryer and condensor and replace it and plan on taking it to a place like jiffy lube or someplace so that they can recharge it, do i have to worry how much compressor oil is in the system already? Don't they vacuum out everything including the oil b4 recharging? or do i still have to measure how much oil to put in the compressor. thanks
Old May 11, 2005 | 12:29 PM
NeoGSR's Avatar
Default Re: AC question.. (mingbling96)
if your simply low on refridgerant, the cut-off switch will prevent the compressor from kicking on....just my .02
Old May 11, 2005 | 12:41 PM
Default Re: AC question.. (NeoGSR)
compressor might be good.. or not, but i dont want to take the chance, i'd rather start off with everything new. If i did that.. can i go about the way i explained above? thanks
Old May 11, 2005 | 01:51 PM
yrethguad's Avatar
Your most reliable answer to that will be from the place you are going to go. I'm sure they will add what is necessary.
Or you could recharge it yourself. It's really easy. I just fixed mine.
Leaking hardline. Took it off, had a place seal it, put it on, and recharged.
Had to charge it to find the leak. Didn't take much heheh.
Old May 11, 2005 | 02:06 PM
Default Re: AC question.. (yrethguad)
i have r12.. and don't want to convert to r134a as i heard its won't be as cold.
Old May 11, 2005 | 03:11 PM
yrethguad's Avatar
If it's empty you don't have any. You're not R-12 OR R-134a. What year of vehicle? I hear you'll save a lot of $ by using 134a, but that's your call.
I didn't say you'd have to switch anyway, so that's irrelevant. Same hoses and lines.
1 Civic I
Jul 12, 2010 02:26 PM
bigchris2000
Jun 18, 2010 07:14 PM
Eaglekper0046
Mar 19, 2006 12:03 PM
