ABS sensor remplacement help!
Old Mar 12, 2008 | 03:22 PM
cast98integra's Avatar
Default ABS sensor remplacement help!
hey guys, i just finished the engine part ( booosted integra ) and now i'm doing the brakes. i will upgrade the front rotors with AEm bigbrake kit and hawk pads all around But i want to have the ABS back on. the previous owner juste ripped off the front sensors, the rear left one and the one on the rear right looks shitty. i'm looking for sensors ( they told me at the local honda dealer it was like 800$ for the 4 sensor including the installation .) and i don't want to spent that much of money. Is it safe to bolt on used abs sensors? i just find front used sensor on ebay for like 30buck, i didn't find any rear ones...can i use the sensors from another model of honda/acura???
Old Mar 12, 2008 | 03:49 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ABS sensor remplacement help! (cast98integra)
What car (year) do you have? The rear sensors are a pain because they mount between the shock bracket and LCA. The rear shock bolts often seize and brake.
Old Mar 12, 2008 | 03:53 PM
i have a 98 teg, GS model with 4X100 hubs. help i have to get it back on the road real fast
Old Mar 12, 2008 | 04:04 PM
wankel kel's Avatar
i saw the ones on ebay also. and need a rear one they are expensive thought 123 each and I havent found a used one yet (rear)
I dont think you can use other sensors and I think you have to be careful with 98+ sensors from what I have read and dealer notes(different parts)
Old Mar 13, 2008 | 10:53 AM
Default Re: (wankel kel)
are you sure that the generation has something to do with the sensors?(obd1-obd2a)....
Old Mar 13, 2008 | 11:59 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (cast98integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cast98integra &raquo;</TD></TR><TR><TD CLASS="quote">are you sure that the generation has something to do with the sensors?(obd1-obd2a)....</TD></TR></TABLE>
They changed the P/N on just one of the rears near 1998. (Check my signature for P/N details.) Realistically, they should be the same. Perhaps the p/n change was to address an issue with the sensors failing.
641iowaguy641
Jul 22, 2013 09:58 AM
foxfai
Mar 31, 2010 08:26 PM
mrbigg9032
Northeast (Sales)
Nov 16, 2008 06:57 PM
JDMCRX
May 28, 2008 06:45 PM
