ABS not working
Old Sep 27, 2004 | 01:43 PM
dclute's Avatar
Default ABS not working
To make a long story short i'm just going to say that my brake lines under the hood were disconnected for about a week while the car was getting worked on we reattached them and bled the brakes but they are softer then they were before and the ABS light is on. Do I need to some how reset the ABS system or what? I can use my brakes and stop but if I need to stop fast I have to pump my brakes. If you can help and give me any suggestions it will be greatly appreciated.
Old Sep 27, 2004 | 02:26 PM
patmcd's Avatar
Default Re: ABS not working (dclute)
If you have to pump your breaks it sounds like there is something wrong. Check the fluid level, double check that they were bled correctly.
Old Sep 27, 2004 | 03:17 PM
dclute's Avatar
Default Re: ABS not working (patmcd)
the brake fluid is filled up and we went around and bled each brake.
Komakazi_830
Aug 5, 2008 10:38 AM
__oversea
Jul 6, 2008 07:51 AM
Moshimoto racing
Nov 15, 2006 06:06 AM
90teg
May 2, 2006 08:20 PM
Teknic73
Jan 19, 2004 08:27 PM
