abs light is on, not blinking...
Old Apr 11, 2003 | 03:13 PM
vain's Avatar
Default abs light is on, not blinking...
when i start my car, usually, the abs and srs lights are on .. then they turn off after like 5 seconds.. but now, the abs light doesn't turn off. i know there are error codes w/ it when it blinks, right? or is there something i need to do to get the error codes? is there anything i can check real quick?
Old Apr 11, 2003 | 05:36 PM
vain's Avatar
Default Re: abs light is on, not blinking... (vain)
anyone?
Old Apr 11, 2003 | 06:11 PM
ggGurl's Avatar
that happened to me one time, then the next time i turned the car on it was gone.... sorry no clue! good luck
Old Apr 11, 2003 | 08:01 PM
Loveless's Avatar
does that mean check abs fluid? if so then I think it's behind the passenger headlight
Old Apr 12, 2003 | 11:09 PM
avs's Avatar
avs
Default Re: abs light is on, not blinking... (Loveless)
Ok im having a same problem too. I would check the brake fluid first. Then jump the ABS wirining harness. The one next to the Engine harness and see what code you get. Then we'll go on from there.
Old Apr 13, 2003 | 05:29 AM
HiRevn's Avatar
Default Re: abs light is on, not blinking... (avs)
Did you check if it is leaking fluid? When my ABS light came on (and stayed on) I brought it into the dealer and they had to replace the entire ABS pump. Hopefully you're not having the same problem, because it's not a cheap fix.
Old Apr 13, 2003 | 12:40 PM
SilverDc2's Avatar
Default Re: abs light is on, not blinking... (HiRevn)
my abs used to come out once in a while b/c i didn't have shocks and in the freeway i would bounce all over the place. you dont appreciate your shocks until you dont have any .
94~GSR
Sep 30, 2005 10:33 PM
vtran8
Jul 14, 2003 01:02 AM
92LudeSI
May 31, 2003 12:51 AM
CNSK
Apr 12, 2003 11:13 PM
redteg1
Aug 18, 2001 02:42 PM
