Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   ABS light came on. what to do? (https://honda-tech.com/forums/acura-integra-6/abs-light-came-what-do-497841/)
GSblueRacing May 6, 2003 03:22 PM
Driving around,ABS light wasn't on, After driving for a while, the Light came on and stayed on. Then I turned engine off and waited 5 mins. Turned engine on as usual ABS light stayed on for 2 seconds and went off as usual, but it didn't come back on again.
What caused the ABS to light upn when i was driving before?
xrocket21 May 6, 2003 04:07 PM
Re: ABS light came on. what to do? (GSblueRacing)
get the code checked
Cru Jones May 6, 2003 04:10 PM
Re: ABS light came on. what to do? (xrocket21)
Quick question, did all of the integra models 94+ have abs?
six_speed May 6, 2003 04:13 PM
Re: ABS light came on. what to do? (B16A3)
except rs.
WiggiE May 6, 2003 04:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrocket21 &raquo;</TD></TR><TR><TD CLASS="quote">get the code checked</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif
GSblueRacing May 6, 2003 06:51 PM
Re: ABS light came on. what to do? (WiggiE)
what code? I don't have the factory stereo unit.. I have aftermarket.
anyone had this ABS problem before? how to fix it? if it even need to be fixed.
Trac226 May 6, 2003 06:56 PM
You should have it checked out. You can start with checking the abs fluid level. It's been known that a bad o-ring can cause the fluid to leak and/or trip the abs light.
NeoGSR May 6, 2003 07:12 PM
Re: ABS light came on. what to do? (Trac226)
yeah, check your fluid and see if it spits any codes out https://honda-tech.com/forums/images/smilies/emthup.gif
tC_Dragon May 6, 2003 07:12 PM
what year is your car? jus askin to find out if u have the older or newer abs
WiggiE May 6, 2003 07:40 PM
Re: ABS light came on. what to do? (pdcdragon)
Take it to a Honda dealer and ask them to read the code for you.
timmy8151 May 6, 2003 09:21 PM
As others have said, first thing you should do is check your brake fluid level for your ABS reservoir. If that isn't the culprit, then you're going to have to jump the service connector with a paper clip. Read the flashes and pull the code from there.
Also, if you use the Search function, you'd find that there are at least 10 threads about ABS lights coming on.
