ABS delete wiring
Old Jan 29, 2023 | 07:10 PM
MisterAKe's Avatar
Default ABS delete wiring
Hey guys I知 about to finish my project with my k swapped integra and I did a abs delete and I was wondering what any of you guys did with your wiring? Because right now it is a complete mess. Thanks!
Old Feb 20, 2023 | 08:11 AM
-16V-'s Avatar
Default Re: ABS delete wiring
I DE pinned from the connector and removed the plugs from wiring harness
Old Feb 21, 2023 | 01:50 AM
MisterAKe's Avatar
And I知 guessing you put electrical tape around the depinned connectors so they wouldn稚 short? Also what did you do about the fuse box for ABS?
Old Feb 23, 2023 | 08:23 AM
-16V-'s Avatar
[QUOTE=MisterAKe;52689160]And I知 guessing you put electrical tape around the depinned connectors so they wouldn稚 short? Also what did you do about the fuse box for ABS?[/QUOTE
DE pinned from the connector and plugs removed. Meaning you will no longer have that run of wires on ur wiring harness. So no need for tape, and dont have to worry about shorts.
Removed it also and abs bulb.
teg racer 877
Dec 14, 2014 01:17 AM
eg-greeny
Jul 26, 2010 01:10 PM
w2 cor
Mar 10, 2008 01:50 AM
