96 Poor mans
Old Jul 18, 2014 | 05:44 PM
Solidis's Avatar
Default 96 Poor mans
Hey guys I bought a b16 a month ago and slowly getting everything.. I have pistons ( are 20 over) and about ready buy valves. Question 1. What valves should I buy I'm not going to boost the car anytime soon.. But I will eventually.. And how do you know when you. Need valve stems..
I'm fairly new. This is my first build..
I currently have a 96 True GSR..
Old Jul 18, 2014 | 06:49 PM
tollickj's Avatar
Default Re: 96 Poor mans
I would stick with the Gsr to be honest.
Old Jul 18, 2014 | 06:57 PM
Solidis's Avatar
Eliaborate
Old Jul 18, 2014 | 07:42 PM
B_Swapped93's Avatar
stock valves, not worth spending $3-400 for :2 bump or drop in compression. ditch 1.6l even if you may boost it one day opt for at least 2.0L
Old Jul 18, 2014 | 08:29 PM
tollickj's Avatar
Gsr is the better motor to work with, can handle more power than the others, better girdle, oil squirters in the block to lubricate the pistons/cylinder walls. Gsr transmissions are the best to turbo, the gears are perfect so your moving and not using too much gas as if you were to use a b16 transmission.
Old Jul 18, 2014 | 09:20 PM
Solidis's Avatar
Ahh OK.. And I think i am gunna stick to my gsr and just save up and boost it.. I might as well sell the b16 head get my money back and piston too
Old Jul 19, 2014 | 12:05 PM
Solidis's Avatar
Any idea how much boost I can run with stock internals or what I should switch out..
Old Jul 19, 2014 | 12:09 PM
gauging by psi is useless, stock internals can hold you till 300 give or take.
Old Jul 19, 2014 | 03:53 PM
Solidis's Avatar
OK thanks now to sell and look at what I'm gunna get as far as brand!
batto24GSR
Oct 25, 2012 08:40 PM
HondaTeKnology
43
Jan 18, 2008 12:58 PM
hifonics
Mar 18, 2007 08:08 AM
Coldth1
Apr 18, 2005 01:12 PM
spoon23_JDizM AkA SpOoN20
Sep 4, 2004 10:08 AM
