96 GSR cel p1362 code. Help!
Old May 11, 2015 | 11:57 PM
C4AcuraDC2's Avatar
Default 96 GSR cel p1362 code. Help!
Hello, I have a 96 GSR and it is throwing a code (P1362) for camshaft position sensor A (Top dead center sensor) no signal, but only when trying to start it after it has been sitting for a long period of time, probably 8+ hours. I will turn the key over to start it and nothing will happen. Sometimes it starts after a few seconds and not throw a code, and sometimes it won't start at all and throw a code (P1362) after about 10 seconds of having the key turned over in the start position.
Other symptoms my car has that I haven't been able to diagnose are stuttering/power cut while maintaining a constant speed (any speed at any rpm), noticeable dip in power between 4-5k and very noticeable dip in power when vtec engages, and severe bogging when kicking the throttle between 4-5k. Keep in mind, none of these symptoms throw a cel.
I have had people tell me that it may be the sensor itself, and I have also had people tell me that it may be out of time, but i just need an input from anybody else that may have experienced these identical issues before so that I don't waste time and money an things I don't need. Thanks in advance!
Old May 12, 2015 | 12:13 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: 96 GSR cel p1362 code. Help!
I think that sensir is in the distributor if i remember right. Try another distributor and see if thats the issue.
Old May 12, 2015 | 12:43 AM
C4AcuraDC2's Avatar
Already replaced the distributor. And shortly after I did that, I found out that the tdc sensor isn't in the distributor housing for OBDII cars :/
Old May 12, 2015 | 10:33 PM
Ferio Wdm Edition
I have a 00 civic and i dont have a tdc sensor anywhere else besides in the distributor.. only thing i can think of closely related to the tdc sensor is the crankshaft positioning sensor behind the crank pulley.. aybe thats what you mean?
Old May 13, 2015 | 09:55 PM
wunfstgsr's Avatar
Loved
Community Favorite
How did you find out its not in the dizzy? It should be in the distributor! replace the distributor with a good one, richporter distributors are the best aftermarket distributors there made with all new parts not refurbished parts.
check your mech timing sound like your timing may have skipped a tooth! but poor engine performace is one of the symptoms of a bad TDC sensor.
bLu92bUbbLe
Aug 22, 2010 03:02 PM
Mugen112
Jun 12, 2009 09:50 AM
BlackGser
Apr 23, 2005 03:45 PM
Malgerus
Aug 15, 2002 07:06 AM
