94 to a 98 integra conversion?does not bolt on correctly?
Old Feb 6, 2004 | 06:22 PM
jdmjohn02's Avatar
Default 94 to a 98 integra conversion?does not bolt on correctly?
For some reason my 94 integra won't bolt on to a 98 front bumper i mean the bottom of the bumper won't bolt on correctly but the top bolts on just fine, and i see me headlights are lined correclty, does anybody knows what the problem is or anybody having the same problem?
Old Feb 6, 2004 | 06:27 PM
illicon2003
Guest
Posts: n/a
radiator support that's just a guess I don't own an integra
Old Feb 6, 2004 | 06:50 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 94 to a 98 integra conversion?does not bolt on correctly? (jdmboi2004)
which part specifically isn't bolting up right?
Old Feb 6, 2004 | 07:26 PM
94tegra's Avatar
sometimes you need to play with it alittle, do you have the 98 headlights cause the 94 will not fit right
Old Feb 6, 2004 | 10:04 PM
tC_Dragon's Avatar
Default Re: (94tegra)
yea... should fit no prob. All u need are the bumpers headlamps, n corners.
Old Feb 7, 2004 | 10:55 AM
jdmjohn02's Avatar
yeah i got the whole 88 up set up and the very bottom of the bumper won't bolt on corrrectly.
Old Feb 7, 2004 | 11:35 AM
id10t
Guest
Posts: n/a
Old Feb 7, 2004 | 11:57 AM
JDC2's Avatar
Default Re: (id10t)
did you buy a used or new bumper? if its used could be tweaked a little just got to play with it to make it fit.
Old Feb 7, 2004 | 12:17 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi2004 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i got the whole 88 up set up and the very bottom of the bumper won't bolt on corrrectly.</TD></TR></TABLE>
Bolt on to where, underneath the radiator support?
Old Feb 7, 2004 | 12:18 PM
oMek's Avatar
Default Re: 94 to a 98 integra conversion?does not bolt on correctly? (PatrickGSR94)
if im correct it only bolts on the top and the sides im not sure if there are any bots on the bottom. maby to hold that big mudflap thing up?
Old Feb 7, 2004 | 12:25 PM
Community Builder
Default Re: 94 to a 98 integra conversion?does not bolt on correctly? (oMekoneDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">if im correct it only bolts on the top and the sides im not sure if there are any bots on the bottom. maby to hold that big mudflap thing up?</TD></TR></TABLE>
9 scews in the top, 1 bolt in each corner up top, 1 screw inside the fenderwell, 1 screw to hold the end of each fenderliner to the bumper, and then 2 plastic retainer clips in that bottom flap.
So I say again, which part isn't bolting up?
Old Feb 7, 2004 | 01:01 PM
jdmjohn02's Avatar
its the very bottom the screws to the plasctic that won't bolt on, and plus my headlights only two screws fit on each side, which suppose to be 4 screws each on each side. This is a new as bumper and new headlights!
Old Feb 7, 2004 | 04:16 PM
Community Builder
Can you take pics of where the problem areas are and post them?
lilpastrana
Oct 1, 2006 05:50 PM
Tony R
Nov 12, 2003 01:02 PM
Miz101
Aug 3, 2003 09:35 AM
TypeR Chris
Dec 19, 2002 12:55 PM
SIK IN DA HED
Mar 7, 2002 09:21 PM
