9005 conversion. thumbs way down!
Old Apr 26, 2004 | 11:53 PM
JAI-DM's Avatar
Default 9005 conversion. thumbs way down!
I did this "mod" a month or so back and it totally melted my passenger side bulb plug. Anyone seen this? I swapped back in the 9006 and they seem to be working ok with my mangled plug. Anybody have a similar problem?
Old Apr 27, 2004 | 12:25 AM
svtec's Avatar
L D E S
Default Re: 9005 conversion. thumbs way down! (INTEGRAJAI)
i agree. it is a failure.
Old Apr 27, 2004 | 12:49 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
well now that they make silverstars in 9006, no more conversion needed (=
Old Apr 27, 2004 | 05:44 AM
dip-set's Avatar
Default Re: 9005 conversion. thumbs way down! (dLo GSR)
it never caused a problem here...
Old Apr 27, 2004 | 06:14 AM
AkiraLite's Avatar
Default Re: 9005 conversion. thumbs way down! (b18b-se)
Been running 9005 for over a year. Love it. Never a problem.
Old Apr 27, 2004 | 06:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRAJAI &raquo;</TD></TR><TR><TD CLASS="quote">I did this "mod" a month or so back and it totally melted my passenger side bulb plug. Anyone seen this? I swapped back in the 9006 and they seem to be working ok with my mangled plug. Anybody have a similar problem?</TD></TR></TABLE>
You must have done something wrong. Were you using stock wattage 9005 (60W)? I saw huge amounts of light increase when I did the switch, and I drove it like that for over a year and a half w/o issue.
Old Apr 27, 2004 | 09:29 AM
94ls's Avatar
that sucks you had a problem with it bro... i ran the 9005 w/ syvania cb's for more than a year as well w/o problems. much approved over stock for sure. like patrick said, were you running bulbs that were more than 65w? that might have been why you fried the wiring. dunno
Old Apr 27, 2004 | 10:45 AM
xplanetearth420x's Avatar
Default Re: 9005 conversion. thumbs way down! (94ls)
ya i have heard alot of good this about 9005 conversion
you must have done something wrong
Old Apr 27, 2004 | 12:10 PM
Rtistik.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">well now that they make silverstars in 9006, no more conversion needed (=</TD></TR></TABLE>
how's the output on these?
Old Apr 27, 2004 | 12:50 PM
dip-set's Avatar
Default Re: 9005 conversion. thumbs way down! (rtistik)
not as bright as the 9005 conversion...
Old Apr 27, 2004 | 02:16 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b-se &raquo;</TD></TR><TR><TD CLASS="quote">not as bright as the 9005 conversion...</TD></TR></TABLE>
Barely brighter, if any, than regular clear 9006's. So in other words, totally not worth the money.
Old Apr 27, 2004 | 02:40 PM
svtec's Avatar
L D E S
Default Re: 9005 conversion. thumbs way down! (PatrickGSR94)
i swear to christ i must be like the only person here that hates that conversion.
my headlights are perfectly free of condensation, water, etc.
i burned 3 silverstars and 2 cool blues in 2 years with this conversion.
i have been running regular 9006 sylvanias for the last year with no problems.
if you drive a lot at night these will fail. 9005's are not made for continous running, period.
Old Apr 29, 2004 | 06:55 PM
JAI-DM's Avatar
I was running 100 watt bulbs, but posted a question about if this was too high of a wattage and everybody said no. So chop this one up to misinformation i guess. Who cares, HId's on the way....
Old Apr 29, 2004 | 06:59 PM
cougar10ag's Avatar
i'm running 9005 silverstars .. there is a SLIGHT glare as the tip of the bulb is not covered so that shines past the blocking plate behind the projector lens.. it's not bad tho. no one flashes me.. and it really helps to see street signs and the output is much much better. on a unlit road it seems like i have spot lights almost
Old May 1, 2004 | 08:42 PM
Bombadil's Avatar
I'm not surprised the 9005's running in the low beam are burning out much more quickly. Indeed, they shouldn't last as long when continuously burning at night.
They are indeed much better than the 9006 Silverstar. The Silverstars are rated at the same brightness as standard 9006's. They have a bluer white light and a beam pattern that is more even. So the "extra" brightness is really just a bluer white color temp and a nicer, more even light across the road. That's what the +30 is about, a perceived increase in brightness.
Sylvania's European version of the Silverstar, sold under their Osram label, is actually brighter than the USA version. It doesn't have the blue coloring on the glass, so the light isn't the same shade of blue/white. But without having to pass through the blue glass, the light is brighter.
A high/low beam arrangement of the standard 9005/9006 puts out 1000 lumens per headling on lows and 2700 lumens on high. Using the 9005/9005 will produce 1700 on low and 3400 on high. No way an Integra using Silverstar 9006's and 9005's can come close to being as bright as using standard $7 Walmart 9005's with the conversion. Or better yet, if you can find $9-$10 Wagner BriteLite 9005's then you'll have a higher temp / whiter light.
I'm surprised by the reports of melted plastic. The 9005 is only 10 watts higher than the 9006 and since it works fine in your high beams with the same connectors, it should work fine in your low beams. This is well under the illegal 85 watt 9006 bulbs, which do melt the plastic in many cars.
[Oh, just saw that he used 100w bulbs ... that was a guaranteed meltdown!]
Old May 1, 2004 | 09:20 PM
xteg95's Avatar
Default Re: (Bombadil)
yea i had the 9005 conversions for about a year and never had any such problems
Old May 4, 2004 | 10:39 PM
scottg's Avatar
Default Re: (xteg01)
i am currently running 9005 silverstars in my low beams and i cant tell hardly any difference from my 9006 silver stars that were in before....i need some hids
Old May 4, 2004 | 10:56 PM
NyQuiL's Avatar
Default Re: (scottg)
im running the 9005 conversion, but i didnt feel to secure using the dremel method on the 9006 harness, so i just went to autozone and bought 2 9005 harnesses. Clean and simple. Have had it for a few months now, no problems at all.
Old May 5, 2004 | 02:57 AM
IntEGNYC's Avatar
Default Re: (NyQuiL)
if you search, you might have noticed similar testimonials on the 9005 conversion.
Lets try to cover some new ground here if were going to post this again, shall we?
Old May 5, 2004 | 03:34 AM
ebelp's Avatar
Default Re: (IntEGNYC)
I think the "9005 conversion" fad has passed and gone.
Old May 5, 2004 | 05:03 AM
Dan GSR's Avatar
Default Re: (ebelp)
screw 9005, 9012 is where its at, same wattage and 88% more lumens
Old May 5, 2004 | 05:07 AM
Dan GSR's Avatar
Default Re: (Dan GSR)
9012 acutually is brighter than than 9005, and has a whiter color to it as well
Old May 5, 2004 | 06:14 AM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
You must have done something wrong. Were you using stock wattage 9005 (60W)? I saw huge amounts of light increase when I did the switch, and I drove it like that for over a year and a half w/o issue.</TD></TR></TABLE>
Same here. replaced 1 bulb after a year and a half. The other is going on 2 years now.
Old May 5, 2004 | 06:17 AM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">9012 acutually is brighter than than 9005, and has a whiter color to it as well</TD></TR></TABLE>
Just looked thses up. Some HID site says they cost the price of a HID bulb!
Where did you get yours?
Old May 5, 2004 | 07:21 AM
TURBODC4TEG's Avatar
Default Re: (ragejed)
never had a problem my silverstar just now blew out after a 1yr so i went with the cool blues this time and its fine
