5-lug conversion on a GSR
Old Nov 11, 2002 | 09:02 AM
b18cya's Avatar
Default 5-lug conversion on a GSR
how difficult is it to do a jdm 5-lug conversion on a GSR?
& i've found the parts for 1300
good deal?
Old Nov 11, 2002 | 09:43 AM
p nut's Avatar
Default Re: 5-lug conversion on a GSR (b18cya)
put that $$ towards something else that will make your car actually go faster.
Old Nov 11, 2002 | 11:18 AM
Ferrell's Avatar
Default Re: 5-lug conversion on a GSR (con)
braking plays a major role just as well.
$1300 is good if it is complete, and legit.
If it is complete, it will bolt right up.
ITR 5-lug gets my vote.
Old Nov 11, 2002 | 11:23 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: 5-lug conversion on a GSR (Ferrell)
the conversion should take 1 - 2 hours to complete.. if that long. It should be a direct bolt on. Once you do one side the other side should take like 5 - 10 minutes.. I'd go for it if the swap comes with wheels as well..
Old Nov 11, 2002 | 12:09 PM
b18cya's Avatar
Default Re: 5-lug conversion on a GSR (Hatchy-Ownzjo0)
negatory, it comes with jdm 16" ITR wheels & tires for another $600
a guy i know offered to install it for me for those wheels. if it isnt that hard to do, is that too much i'd be giving to him?
the guys selling the conversion said that those wheels can sell for over 1k
i really want to do it b/c i've fallen in love with the USDM gunmetal ITR wheels, & i can get new ones for CHEAP!!!!!
[Modified by b18cya, 1:14 PM 11/11/2002]
Old Nov 11, 2002 | 12:11 PM
311's Avatar
311
straight bolt up except the rear lower control arms. on the usdm itr at least. not sure about the jdm itr. I have usdm itr 5 lug and had to use my gsr rear LCA. Other than that, pretty easy except pleading the brakes.
Old Nov 11, 2002 | 12:20 PM
b18cya's Avatar
Default Re: 5-lug conversion on a GSR (311)
what exactly is required to do the conversion on a GSR?
im afraid im gonna get sold more parts than what i need.
does anyone know of a good tech article on this?
[Modified by b18cya, 1:35 PM 11/11/2002]
Old Nov 11, 2002 | 12:46 PM
GSR2001's Avatar
Check on http://www.ebay.com their is one 5-lug conversion auction under Acura Integra. The last time I looked the bid was up to $400.
Old Nov 11, 2002 | 01:01 PM
b18cya's Avatar
i dont think the rear lower control arms are included because i can use my stock ones. at least thats what we did on my bud's civic hatch when we installed the rear GSR brakes. the rear LCA's that were on the car worked just fine
Old Nov 11, 2002 | 01:04 PM
b18cya's Avatar
if converting the two rears to 5-lug is the same as installing rear GSR discs on a civic, that will be a breeze.
but im not too sure of how hard the fronts are to do.
Old Nov 11, 2002 | 01:17 PM
Jesse H's Avatar
I can spend $1300 and get much nicer brakes than oem ITR.
[Modified by Jesse H, 4:18 PM 11/11/2002]
Ferrell's Avatar
if you plan on using ITR struts/springs, then you need the LCA's.
Old Nov 11, 2002 | 01:18 PM
H-T Poker champion
Same thing.. Same process and everything... Ive done it.. its simple!
Old Nov 11, 2002 | 01:39 PM
b18cya's Avatar
i wasnt planning on using the ITR struts/springs. do i have to? i was just gonna use my current H&R spring/stock shock setup.
Old Nov 11, 2002 | 02:12 PM
Anyotherone's Avatar
My opinion... take that $1300, buy the fastbrakes spec R brake kit, and some rota 15" wheels. Slips, subs, grids, groupN, they all weigh in around 12lbs so that's around 3lbs less per wheel than the stock ITR.
It makes sense!
Old Nov 11, 2002 | 02:29 PM
b18cya's Avatar
Default Re: 5-lug conversion on a GSR (Anyotherone)
except i want these wheels
Old Nov 11, 2002 | 03:10 PM
migs's Avatar
If you use the 98+ JDM ITR 5lug. You will need to use JDM ITR axles. The difference is that the USDM ITR uses a 32mm axle nut while the JDM is a 36mm. PITA if you ask me.
Here is mine
Old Nov 12, 2002 | 06:28 AM
b18cya's Avatar
Default Re: 5-lug conversion on a GSR (Migs)
the jdm axles are included
& i really like that car!
Old Nov 12, 2002 | 07:03 AM
mojoGSR92's Avatar
This if for the 90-93 Integra, but it should apply all the same.
This is courtesy of battlecat/ryank on http://www.g2ic.com/ :
http://battlecat.8m.com/ITR%205%20lug%20on%20DA.htm
Hella_Fresh
Northern California (Sales)
Feb 16, 2013 11:39 AM
Hella_Fresh
Feb 16, 2013 11:36 AM
ek_will
Northeast (Sales)
Mar 5, 2009 11:16 AM
d0nkeyxPunch
Sep 25, 2005 08:47 AM
