5 lug conversion
Old Jun 4, 2009 | 09:34 PM
2fast4urass's Avatar
Default 5 lug conversion
would a 5 lug spindle from an RSX fit directly on to 4 lug 1996 integra?
Old Jun 5, 2009 | 01:50 AM
BlueIntegraBoy's Avatar
Default Re: 5 lug conversion
No, it will not fit
Old Jun 10, 2009 | 08:54 AM
what about a 5 lug from a 96 accord the 6 cyclinder
Old Jun 10, 2009 | 08:59 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
no.
Old Jun 10, 2009 | 09:02 AM
B serious's Avatar
The CR-V spindle should fit. You might need an alignment afterwards. You will need 36mm axles. You might be able to just use the CR-V axles all together. If not, you can get JDM ITR 36mm axles (expensive) or you can take prelude/accord/cr-v outer joints and mate them to your axles.
The CR-V spindle comes with ITR sized brake calipers/rotors. I think it's basically a 96-00 EX/SI spindle with a JDM ITR hub and brakes on it.
What are you going to do about the rears?
Old Jun 10, 2009 | 09:04 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
96-97 Accord V6's (the first years for the V6) used the same 4x114.3 hubs as the I4 Accords.
Old Jun 10, 2009 | 12:33 PM
now if i change the spindle would i have to change my coilovers?
Old Jun 10, 2009 | 04:36 PM
Community Builder
I wouldn't think so.. the coilover attaches to the lower control arm and an upper mounting point on the unibody of the car.
Boriqua0555
Jun 28, 2007 10:13 AM
TA Performance
May 9, 2007 12:46 PM
NCEM1
Jan 29, 2006 07:19 PM
SPOONfdEK
15
Apr 1, 2005 03:39 AM
h22teg
Mar 28, 2005 07:09 AM
