4dr's window getting stuck
Old Mar 3, 2003 | 04:58 PM
1hotintegra's Avatar
Default 4dr's window getting stuck
do 2001 4dr's windows typically get stuck. it may be from the cold but idk??
Old Mar 3, 2003 | 05:21 PM
89civicdx's Avatar
Default Re: 4dr's window getting stuck (1hotintegra)
Are the getting stuck or just hard to put down...if they are having trouble going down you can buy a silicone spray and lubricate the rubber seals around the window frame this way the windows will slide down easier.
Old Mar 3, 2003 | 07:20 PM
B U N M A N G O's Avatar
my driver's side rear window kept getting stuck when it was down (it wouldn't go back up)... I took it to the dealer (it was under warranty) and they first thought it was the window regulator, so they replaced that free... then the next day it happened again, so I took it back to the dealer, and they had to re-mount the window to some bracket that holds it, or something like that.
RBaluca.com
Aug 20, 2006 02:08 PM
intgraCA
May 27, 2006 01:41 PM
variablevalve
Feb 5, 2004 03:44 AM
