2k idle!
Old Feb 7, 2006 | 07:53 PM
b_serious's Avatar
Default 2k idle!
i have a b18b ls swap in my 98 coupe.. its always idles at just under 2k and my gas milage is raping me also.. i took carb cleaner and checked for leaks.. all around the intake mani/throttlebody and iacv.. no CEL's either.. anyone have any idea on what it is?
Old Feb 7, 2006 | 10:09 PM
b_serious's Avatar
Default Re: 2k idle! (b_serious)
any1
Old Feb 7, 2006 | 11:22 PM
tusnamiep3's Avatar
maybe your idle sensor, but I'm not totally sure.
Old Feb 8, 2006 | 12:43 AM
foam's Avatar
Is it revving? Or just idling? Maybe adjust the idle?
Old Feb 8, 2006 | 08:04 AM
b_serious's Avatar
Default Re: 2k idle! (foam)
naw idle screw i already played with.. and yea its just idling that high its not bouncing
Old Feb 8, 2006 | 08:08 AM
DA jeshy's Avatar
keep updated want to know what was wrong and how to fix it
Old Feb 8, 2006 | 10:05 AM
b_serious's Avatar
Default Re: 2k idle! (DA jeshy)
will do.. bump
Old Feb 8, 2006 | 01:46 PM
b_serious's Avatar
ok i think i found 1 problem.. the throttle body butterfly.. when i hold it closed really tight by hand the idle will drop to about 1000-900 rpm.. still a little high i think.. anyway to adjust it? i already cleaned the **** out of it
Old Feb 8, 2006 | 02:06 PM
98IntegraLSNonVtec's Avatar
just a guess, but have you messed around with the throttle cable? Try loosening it a bit and that might fix your problem.
Old Feb 8, 2006 | 05:42 PM
b_serious's Avatar
Default Re: 2k idle! (98IntegraLSNonVtec)
the spring loader that pulls the throttle closed has an adjustment screw where it rest that is supposed to be fulley closed.. its on the bottom.. i adjusted it and the idle screw plus the cable to get it to about 800 rpm idle.. i thought wow it was just that easy..
then i test drove then the idle started bouncing from 0-1000 when im not on the gas
now its just doing that.... tps sensor?
90Rexx
Jul 2, 2008 08:53 AM
mad21kid
Feb 18, 2008 12:52 PM
kaj
Sep 1, 2004 04:37 PM
stRodda
Jan 13, 2004 04:32 PM
Vp Special K
Apr 4, 2003 09:14 PM
