1990 LS. Weird Overheating issues.
Old Oct 12, 2005 | 09:48 PM
. M i c h a e l's Avatar
dotmichael to you
Default 1990 LS. Weird Overheating issues.
I just picked up a 1990 LS yesterday. The radiator was bone dry when I got it, so I put fluid in it and drove the hour or so home. I stopped to drop my friend off and while on the slanted road, it started to overheat. I drove home, which is two roads down and it cooled down again to normal operating temp again.
I came home..parked and that was that. This morning I went to run a quick erran, came right back home and as I pulled into my driveway, the car just shut off. No reason. Tried starting it again and it would just crank.
Went out to drive it about an hour ago..first 5 minutes or so it was fine..then it started overheating when I took my foot off the gas and let it coast..I'd give it gas, speed up and it'd cool back down. I turned around in a driveway and it shot all the way to the red. I stopped the car and it cooled back down. Continued driving and it shot right back up all the way after 10 or so seconds. I turned the car off and waited for it to cool down. I then drove back to my house..idled at it..then the idle started lowering slowly by 50-100 rpm or so and just shut off.
I parked it and here I am..hating the car I just bought.
I dont know whats wrong with it. Since I got it, I changed the plugs (which were completely shot..black and no cathodes left) the plug wires, (which were set in the wrong firing order on the distributor) distributor cap and the oil..which was very dirty. The previous owner took very poor care of the car it seems.
The car has 125,810 miles on it. I'm going to reset the ECU tomorrow, run seafoam through..see what it does.
Old Oct 12, 2005 | 10:23 PM
DA6righthand's Avatar
Default Re: 1990 LS. Weird Overheating issues. (. M i c h a e l)
DONT RUN SEAFOAM, search and you will see why. it makes more probs than its worth. try replacing your thermostat. that makes the temp go up and down alot when you are driving it. itll take you about 10 bux and no more than an hour to replace....just dont run seafoam. if a thermostat doesnt fix it, then id take it to a shop just to see what they say.
thanx
justin
Old Oct 12, 2005 | 10:28 PM
dotmichael to you
Default Re: 1990 LS. Weird Overheating issues. (DA6righthand)
i've read NOTHING but rave reviews on this website about seafoam. i just change the oil and plugs right after using it. i used it on my mercedes and didnt have any problems..could you find me some information as to why i shouldnt use it?
Old Oct 13, 2005 | 02:39 AM
Monkey Z.'s Avatar
I've ran seafoam in 2 integras and it didn't seem to do anything but get carbon off of sh*t like its suppose to... It could be a broken fan switch, does the fan turn on?
Old Oct 13, 2005 | 09:20 AM
dotmichael to you
Default Re: (Monkey-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Monkey-DA &raquo;</TD></TR><TR><TD CLASS="quote">It could be a broken fan switch, does the fan turn on?</TD></TR></TABLE>
the last time it overheated i turned the accesories on and i heard the fan kick on
Old Oct 13, 2005 | 09:54 AM
Default Re: (. M i c h a e l)
last time i read about seafoam, it was causing problems. ill search and try to find it but im betting your prob would be a thermostat...
Old Oct 13, 2005 | 10:16 AM
dotmichael to you
Default Re: (DA6righthand)
i just let it run in my carport for 15-20 minutes or so..when i went back out it wasnt overheating...but the lower radiator hose feels cold and its leaking coolant.
Old Oct 13, 2005 | 10:21 AM
dotmichael to you
just let it sit another 5 minutes and went back out..it was started to run a bit hot..i revved it to 2,500 rpm and the temperature dropped right back down.
Old Oct 13, 2005 | 10:27 AM
civiclxb16a's Avatar
i still think we need to take that therm out if the lower is cold it is not getting thur the motor lets do the small stepsfirst therm then we can do the water pump but i still say it is your therm!
Old Oct 13, 2005 | 11:08 AM
BlackLudeSi's Avatar
Default Re: (civiclxb16a)
Agreed my DA did the same thing, all in the thermostat
Old Oct 14, 2005 | 05:06 PM
Default Re: (BlackLudeSi)
I FIXED IT. it was the therm and he needed anti freeze..lol now i don't know why it stalls we drove it it had heat and it didn't over heat so we came back to his place let it sit for a while and still nothing no over heating and as i got in my 7 and started to roll he was like YO IT TURNED OFF...lol it did for no reason it just shut off.... so i can't figure that out any ideas? by the way mike is a crazy **** tring to get me shot..lol never hang out with him he is trouble!!...lol
AngeloM
Honda Civic (2001 - 2005)
Apr 14, 2025 02:14 PM
sc34dc4
Apr 29, 2010 07:50 AM
sc34dc4
Apr 28, 2010 07:37 AM
sc34dc4
Apr 27, 2010 07:35 PM
16bit_Villain
Mar 10, 2005 02:44 PM
