1990 integra ls problems help
Old Sep 7, 2010 | 01:24 PM
kingjames0509's Avatar
Default 1990 integra ls problems help
My 90 integra stalls when i shift 1st to 2nd stall then i let go clutch it jumps itself then 2nd tho 3rd and ect.... then all of a sudden my oil pressure light started blinking somebody tell me something suggestions anything
Old Sep 7, 2010 | 01:41 PM
Teg LS's Avatar
Default Re: 1990 integra ls problems help
it stalls every time you shift? that sentence is hard to read
Old Sep 7, 2010 | 01:48 PM
brettj20's Avatar
maybe check your oil
Old Sep 7, 2010 | 01:56 PM
oil is full it stalls every time i shift then the oil light came on started blinking
Old Sep 7, 2010 | 02:33 PM
brettj20's Avatar
does it idle ok ?
Old Sep 7, 2010 | 02:46 PM
DumaDA's Avatar
sounds like the oil pump could be going out. I'd be careful running the car like that until you figure it out, oil starvation could ruin the engine
Old Sep 7, 2010 | 03:33 PM
yes idles fine idle dies while switching gears if im not excelerating it runs fine no oil light no nothing soon as i start driving it dies between switching gear then i let go clutch and it jumps in back then the oil light starts going off its mind boggling tommorrow i have to check oil pressure and iac thats the only thing i could think of doing unless someone has had this problem before i just rebuild engine too new piston rings new valves new belt new everything
Old Sep 7, 2010 | 03:37 PM
DumaDA's Avatar
you did it yourself or had it done?
Old Sep 7, 2010 | 04:09 PM
had it done why
Old Sep 7, 2010 | 04:12 PM
DumaDA's Avatar
because rebuilding a motor is risky business, one thing done incorrectly or not to spec and the motor is done.
Old Sep 7, 2010 | 04:28 PM
they professionals ill check oil pressure and see what happens nobody else had this problem before though huh
negusjuda
Jun 21, 2011 12:57 PM
raverx3m
Dec 6, 2010 06:06 PM
GraphiteMW
Sep 2, 2007 11:07 AM
KFBhonda
12
Oct 12, 2005 01:30 PM
lil_jess
May 27, 2005 06:06 AM
