11.1 compression
Old Apr 23, 2003 | 05:38 PM
redteg's Avatar
Default 11.1 compression
i am running 11.1 compression with the bill gude racing packageon my integra ls .will i have any problems with pinging or anything else. i live in the northeast and i use 93 and 94 octain but since we have cold winters they put preservatives in the gas in the winter. will this effect my motor. most people say no but i just want to get a deffanet answer.
Old Apr 23, 2003 | 06:28 PM
EG(6)SR's Avatar
Default Re: 11.1 compression (redteg)
I don't think so. 11.1 is a pretty conservative compression ratio. I'm pretty sure that the new M3's are running a 11.5:1 compression ration, and those motors are suppose to be oem reliable. Freind of mine, is building an all motor lsVtec, with CTR pistons, milled head, and pnp head, should be in the neighborhood of 12.4:1 and he's going to run pump gas. To go even further, I've heard of members on this board going as high as 13:1 and still running on pump gas. In my opionion, anything over 12.5:1 is gettting risky of pinging and needs to be tuned to run on pump gas.
For the perservatives, I've got no experience with that being in california and all. But heck, winter is basically over.
Old Apr 23, 2003 | 07:26 PM
redteg's Avatar
Default Re: 11.1 compression (EG(6)SR)
yeah i agree thanksfor the help i don't think 11.1 is that much of a difference. factory gsr run 10.5.1 11.1.1 is only a half point higherthatsnot much. thanksany other info will be appreciated
Old Apr 23, 2003 | 08:19 PM
1 2 NV's Avatar
umm, if u have this on ur integra what good is it goin to do to ask a question. its already too late unless u plan on pullin the head off for another one. gude is known for milling the **** outta heads to bump compression.
P1mpSlap's Avatar
From what i've PERSONALLY seen, 12.5 : 1 is the highest you can run on pump gas. But the guy ran 2 OEM head gaskets to drop it a bit. He also had some extensive tuning.
11.6 : 1 is supposedly the limit for 93/94 octane.
But you never know..... tuning does wonders!
Old Apr 23, 2003 | 10:09 PM
M-Type's Avatar
Default Re: (P1mpSlap)
well type R motors area tuned real well already and they're more than the 10.5:1 GSR motors. They only make like 160whp
Old Apr 23, 2003 | 10:29 PM
AllmotorJunkie's Avatar
YES....only if you use 87 or lower octane petro.
Don't be too paranoid. 11:1 is a conservative compression ratio.
Peace
Old Apr 23, 2003 | 10:46 PM
OBDI JEDI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg &raquo;</TD></TR><TR><TD CLASS="quote">yeah i agree thanksfor the help i don't think 11.1 is that much of a difference. factory gsr run 10.5.1 11.1.1 is only a half point higherthatsnot much. thanksany other info will be appreciated </TD></TR></TABLE>
factory USDM GSR's run 10:1 CR
Old Apr 24, 2003 | 07:39 AM
95 integra's Avatar
Default Re: 11.1 compression (OBDI JEDI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBDI JEDI &raquo;</TD></TR><TR><TD CLASS="quote">
factory USDM GSR's run 10:1 CR </TD></TR></TABLE>
Yea, whats up with 2 people getting that wrong. Anyway the Type R runs a 10.6:1. The new and all mighty RSX-S runs 11.0:0, so I dont think you should have any problems.
Evolsport
Jul 17, 2009 12:44 PM
kantfadedisazn
21
Sep 17, 2006 11:10 PM
spoonEGcivichatch
Sep 18, 2005 09:51 AM
90da4dr
Mar 9, 2003 05:18 AM
wickedEFguy
Feb 3, 2003 11:14 PM
