95 Del Sol "NO START" and cruise control problems
Old Mar 23, 2014 | 06:53 PM
  #51
tony_2018's Avatar
Fish Twig
Default Re: 95 Del Sol "NO START" and cruise control problems
Snap didn't realize you're in Tx or I would've driven up there to see whats going on.
Old Mar 23, 2014 | 07:06 PM
  #52
tony_2018's Avatar
Fish Twig
Originally Posted by harley4jcs
OK , This it what I think I understand:
No easy testing after jumping pin 7.
You no longer think the ign switch is a factor. ( was that the jump pin 7 test ??)
Should I no longer check for continuity of the switch positions ? ( I have not done that yet.)
"To test if the ignition switch is the culprit I just need to do a continuity check as listed in the diagram ?? I know something will be a miss in ON III position since it has not started with the key for 2 years BUT ON II should check out as listed, correct ??
PS: Won't this test be as hit & miss as the actual problem ?? For instance, the last 3 times I tried to start the car, the pump came on & the engine fired right up. So if I was testing the switch at that point it should test fine, UNTIL I was getting the "NO START" condition correct ??? "
"OK, I'm really going to show my true colors here: can I just run a switched ground to pin 7 (actually the green & yellow wire) & let her rip ??? I want ( and need to be so done with this quickly) even temporarily, so I can get the car moved ??"
Since I just had the ecu redone , I'll send it back to Houston as soon as I get the car where it can sit again..
I think I know what ground wire your tapping but the question is why is the main relay not receiving that signal itself. You're gonna have to trace that wire to where it goes.
Old Mar 23, 2014 | 07:48 PM
  #53
Former User's Avatar
Additional tests can be done but, given that the pump always primes when pin 7 is grounded, the ECU is almost surely toast, as I already said.
You no longer think the ign switch is a factor. ( was that the jump pin 7 test ??) Should I no longer check for continuity of the switch positions ? ( I have not done that yet.)
Nothing that you have posted points to the ignition switch as causing the pump not to prime. You should, however, do the tests to see if the no-crank problem is caused by a bad ignition switch.
Again, nothing that you have posted points to the ignition switch as causing the pump not to prime.
Stop paying somebody to repair your ECU. I seriously doubt that all bad ECUs can be diagnosed and repaired. Invest in a known good P28 that comes with a guarantee that it works.
Old Mar 24, 2014 | 05:52 AM
  #54
harley4jcs's Avatar
"Stop paying somebody to repair your ECU. I seriously doubt that all bad ECUs can be diagnosed and repaired. Invest in a known good P28 that comes with a guarantee that it works. "
This advice really surprises me. My past experience has been that 15-20 year old ECUs would have known issues very similar to the know issue of the 20 year old MFPR (solder connections failing). In the case of the p28 I understood the chip, and or several capacitors would go bad with age & this was a routine repair. My car is bone stock (with the exception of a starter button). I have a post looking for a known good P28. Does anyone know of a source for non chipped (stock) p28s ??
Old Mar 24, 2014 | 06:00 AM
  #55
Your surprise comes from the fact that you have much more confidence in the idea of "ECU diagnosis and repair" than I do. I believe the ability to diagnose and repair bad ECUs is limited.
  #56
harley4jcs's Avatar
"I think I know what ground wire your tapping but the question is why is the main relay not receiving that signal itself. You're gonna have to trace that wire to where it goes."
I agree for the long term fix BUT that's Not The Question, This is the question:
"Can I bypass my ignition switch to manually energize my main fuel pump relay to turn on my fuel pump so I can get the dang car out of my driveway?? I need to run it 60 miles up the road where it can sit until I got the issue under raps.
IF YES, What would be the best way?? Run a switched ground wire to pin 7's wire at the ECU ??? This will turn on the fuel pump for sure.
ANY THOUGHTS ?? Thanks Harley "
Old Mar 24, 2014 | 06:09 AM
  #57
harley4jcs's Avatar
You would have a much better idea on the subject than I. My experience is very limited on this issue. Like clockwork, at year 15, a 300 lexis ECU will start dumping fuel in cyc 3&5 in scary amounts (raw gasoline dripping from the tail pipe). Pulled the ECU sent it off to be repaired 7 years ago & it is still working just fine.
Old Mar 24, 2014 | 06:16 AM
  #58
I don't want to leave you with the impression that I think Honda ECU repair is impossible. Clearly, in some cases, a bad ECU can be repaired. What I'm saying is that I don't believe that all or even most bad ECUs can be diagnosed or repaired.
With this said, it's possible your ECU could be repaired. This is worth pursuing if your previous ECU repair was warrantied. Otherwise, I would be skeptical about a company telling you that they can definitely fix any bad ECU for a fee.
Old Mar 24, 2014 | 06:22 AM
  #59
harley4jcs's Avatar
Any ideas where to find good stock P28 ECUs ??
Old Mar 24, 2014 | 01:10 PM
  #60
harley4jcs's Avatar
I've got a P28 in the mail headed this way...I'll post what happens next.. If this corrects the issue I'll be looking for a spare, so if you have one you are willing to part with send me a PM. Thanks for all the help. Harley
Old Mar 24, 2014 | 01:33 PM
  #61
tony_2018's Avatar
Fish Twig
Why did you send it in in the first place and what was the turn around timeframe on the the rebuilt ecu and how much did they charge? I don't even think its worth it to "rebuild" an ecu because alot can go wrong and only a pro with circuitry knowledge, PLUS the original honda schematic of the ecu itself will be able to repair the ecu. This task is not easy and requires time to look over the entire circuit.
Old Mar 24, 2014 | 01:36 PM
  #62
tony_2018's Avatar
Fish Twig
If you say grounding pin 7 sends power to the fuel pump and you're able to make the car run than by all means ground it, but its not something i would do because thats actually a security issue. You're setting your del sol up to be stolen. Good luck.
Old Mar 26, 2014 | 07:51 AM
  #63
harley4jcs's Avatar
IF YES, What would be the best way?? Run a switched ground wire to pin 7's wire at the ECU ??? This will turn on the fuel pump for sure."
This is a question ( that I've asked 3 times w/o an answer), not a statement.
I sent in my ECU because my car would not start after replacing the MFP Relay & as far as I know it's the original 20+Y/O ECU. Paid $75 + potage, took about a week or so turnaround.
Old Mar 26, 2014 | 08:14 AM
  #64
SeaMus MaCk's Avatar
Your fuse may also be loose for your fuel pump under the hood. It happens to the one for my radio...Make sure it's in all the way...I would actually replace it if you haven't...I think its a 15amp fuse....sometimes the simple things we over look like a bad ground or a blown fuse will fix the problem.
Old Mar 28, 2014 | 01:45 PM
  #65
harley4jcs's Avatar
AN UPDATE ON MY WOE : Yesterday got the different ECU, Plugged it in and SHAZAM just like when I cleaned the ground the car fired right up !!! This is after 2 days with a totally dead pump & over a 100 tries, including 4 or 5 just before switching ECUs. Plugged in the different ECU & BANG the Pump immediately came on & all was well. Started her up 10-15 times ran a few errands & OF COURSE buttoned up everything BECAUSE I WAS SURE ALL WAS WELL !! Well this morning (just overnight) went to move the car and WTF, just like before NO FUEL PUMP = NO START !! I mean DANG this deal has really got my goat. While running around yesterday I toped her off with 4gals of high test, noticing the last fill up was the end of July 2013 !!! What the heck could be going on at night ??? When I do get her to run, Runs well, runs for hours, starts on & off 10-15 times at least. THEN the next morning It's back to square 1 , for at least 5 or 6 times now!
Old Mar 29, 2014 | 06:57 AM
  #66
tony_2018's Avatar
Fish Twig
It must be losing continuity somewhere. This is where you just need to get technical with a meter man. Might wanna look into replacing the ignition switch, I don't mean the whole column and key. Also look at the starter cut relay as well. Your starting issue reminds me of my sisters integra where it would start fine and then out of no where it wouldn't start at all. Changed out the ignition switch and all was good. I have not heard back from her, thank god......
Old Mar 29, 2014 | 08:02 AM
  #67
harley4jcs's Avatar
SO my testing shows at this point if I want to drive the car every other day I should be good !! You guessed it, this morning the fuel pump fired on the 1st try & I'm guessing I'll get to drive all day if the past is any indication. A VERY GOOD POINT is the car has never stuck me anywhere except my drive way !!
Old Mar 29, 2014 | 08:19 AM
  #68
harley4jcs's Avatar
I think that is a good call Tony: Can I get help in lining out the path from the key to the fuel pump? Ever since I cleaned the ground, if the fuel pump runs the car starts right up.
QUESTIONS
1) procedure to get to the ign switch?(steering columns tend to be tricky in my experience)
2) any contacts, fuses to clean, or anything else to check in relation to having the fuel pump energized upon turning the key to ON II ??
3) are there any test procedures that would give more insight ? And if so, is it correct to assume that the "NO FUEL PUMP" condition has to be in play to get a correct or true test ??
Old Apr 1, 2014 | 06:26 PM
  #69
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Would you please post the info on page 72. I need to run down a sporadic fuel pump condition.
As per request:
Old Apr 1, 2014 | 08:26 PM
  #70
tony_2018's Avatar
Fish Twig
The only way the fuel pump is going to prime is if it gets a signal from the ignition harness, think about it. The page I posted with instructions on how to test the main relay shows it needs a signal from the ignition. This is the only conclusion I can come to is that something is iffy with the ignition switch.
Old Apr 2, 2014 | 05:40 AM
  #71
harley4jcs's Avatar
QUESTIONS
Old Apr 2, 2014 | 05:42 AM
  #72
harley4jcs's Avatar
This is a question ( that I've asked 5 times w/o an answer), not a statement.
Old Apr 2, 2014 | 07:02 AM
  #73
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
After all of this, there is two things that come to mind that I'm not sure have been discussed.
You tried two ECU's and the second ECU worked initially then started acting the same as the original. Do you know if all the signals going to the ECU are in good order? Could there be a short that is straining and even possibly killing ECU's with use?
The other thought is the fuel pump... I will admit, I really hastily skimmed through the three pages of thread so could have missed it but.... Have you done any testing of the fuel pump? Could it be sticking, it always gets the signal but sometimes can't break free to pump and sometimes can?
I will hazard a guess that folks are avoiding the bypass question being it's not a proper fix.
Just like anything you could bypass the systems by just finding out what voltage and what current are required for the pump (fan, light, etc). Then run wire from the battery to your custom built voltage regulator circuit then to the item you want power.
The other area you may have to be concerned with is whether or not any of the other systems need feedback from the item you are "hot wiring". If they do you have to emulate that feedback.
However, that is a really hokey way of going about things. I mean you say it is so you can put it up the road to where it can sit until fixed, yet you say it runs every other day so you could have driven it there at any time and left it to be worked on.
I may have missed some bits, I did only skim through the three pages but I am willing to bet that these thoughts might be pretty close to some other members as to why they would be dodging the bypass question religiously.
Old Apr 4, 2014 | 10:38 AM
  #74
harley4jcs's Avatar
(ECU acted the same the next Morn, Not much use, If ECU is dead how does it run so perfectly if the F/P will prime?? No I do not, That is what I'm hoping to get help with.)
(F/P is new & works every time the ECU pin was jumped to ground)
( Car is moved, 60Miles (needed to start at a time I could get a ride back) drove great, still need to fix it.. )
There is no rime or reason as to when it will or will not prime that I have found. I am believing it is the Ing switch at this point & looking for help to check, clean, or replace the switch or fuses, connectors, wires or anything someone can think of from the key to the M/Relay or ECU. Thanks
Old Apr 4, 2014 | 07:28 PM
  #75
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default 92-95 No Start ECU
I'm assuming you have the D16Z6 motor from your earlier posts. So since you are still having issues and you are confident your mechanical and ignition timing is correct (by running well when it starts). I will post the pages pertaining to the No Start diagnostic. This first one is #1 in the list to diagnose for No Start, the ECU.
More to come.
