Bleeding the 5th generation Civic cooling system
Old May 25, 2009 | 08:28 PM
SiBlueEG6's Avatar
Default Bleeding the 5th generation Civic cooling system
I bought a si civic with a d16z6 and turbo, the motor had the heater hose blocked off with a cap, and the line to the heater right above, now i hook up the hose an try my heat and with in 15min its overheating.
why????
Old May 25, 2009 | 10:22 PM
Former User's Avatar
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
So the two heater hoses are disconnected from the firewall and the ends of the hoses are plugged, right? And when you reconnect the hoses to the firewall, the engine overheats, right?
If so, after reconnecting the hoses, did you top off the radiator and reservoir with coolant and then bleed the cooling system of trapped air?
Old May 26, 2009 | 03:23 AM
SiBlueEG6's Avatar
Default re: Bleeding the 5th generation Civic cooling system
thank you very very much i did not bleed the system but i did add more fluid and then it started to overheat bad and when i opened the cap it was steaming and flying out. only one hose is off at the first spot to the right and has a cap other hose is hooked up.
Old May 26, 2009 | 04:25 AM
civic_driver's Avatar
Be careful with that radiator cap. Make sure when you open it that the coolant is cold enough not to scald you.
Old May 26, 2009 | 04:33 AM
kp's Avatar
kp
If you can't wait for it to cool down, open it very very slowly, until all the pressure escapes. Wear some heavy duty gloves.
Old May 26, 2009 | 07:24 PM
jdmpoweredsol419's Avatar
if you bought the car that way, the heater core is probably leaking.
Old May 26, 2009 | 07:53 PM
I've never tried this. If you do it this way, does any coolant spill out the radiator?
Old May 27, 2009 | 04:27 AM
SiBlueEG6's Avatar
thats what someone else told me the core was most likely bad.
thanks all ill just keep no a/c/or heat.
dam the rain on or off a bike lol.
Old May 27, 2009 | 08:24 AM
kp's Avatar
kp
I agree. What reason would someone have to bypass the heater core otherwise? There's an inline valve controlled by your hot-cold climate control inside the car that bypasses it quite well.
If you wait maybe 1 or 2 minutes, it's usually cool enough that very little or no coolant comes out. In my experience just hot air escapes.
Old Mar 17, 2011 | 11:57 AM
dirtygerman's Avatar
Sorry to bring this from the dead, but Is it possible to delete the bypass hose going from the coolant pipe to the intake manifold? if not could someone explain to me what it does? thanks
Old Apr 7, 2011 | 07:33 PM
No love for the newbie?
luvinthelude
Feb 11, 2014 06:17 AM
sergeant dukesalot
Apr 2, 2010 07:47 PM
Joseprz
14
Aug 25, 2009 05:05 PM
soclean1k_JDM
May 4, 2009 09:31 PM
LStegvtec
Nov 19, 2005 01:42 PM
