[FAQ] DIY 94-01 Integra Maplight in 92-95 Civic
Old Feb 25, 2007 | 01:11 AM
  #26
BlueIntegraBoy's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (wlee112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wlee112 &raquo;</TD></TR><TR><TD CLASS="quote">
look at the motor.. its located to the rear of the sunroof.. are you sure the motor would be in the way?</TD></TR></TABLE>
This is what I heard. Maybe something else is in the way.
Old Apr 14, 2007 | 05:26 PM
  #27
kos99ngel's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (BlueIntegraBoy)
very helpfull thanks
Old Apr 14, 2007 | 06:05 PM
  #28
kos99ngel's Avatar
Each side of the light lights up individually right?
Old Apr 14, 2007 | 06:08 PM
  #29
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (kos99ngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kos99ngel &raquo;</TD></TR><TR><TD CLASS="quote">Each side of the light lights up individually right?</TD></TR></TABLE>
Yes, which is why you need to connect the two grounds.
Old Apr 14, 2007 | 06:09 PM
  #30
jdizzle!
Guest
Posts: n/a
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (Harryflores)
Old Jul 18, 2007 | 07:22 AM
  #31
SinglecamMitch's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (jdizzle!)
Just did my ek maplight into my eg6... LOVE it Blacked out... PICs soon!!
Old Jul 18, 2007 | 04:15 PM
  #32
Hella_Fresh's Avatar
Default Re: [FAQ] DIY 94-01 Integra Maplight in 92-95 Civic (SinglecamMitch)
yea lets see some interior pics of them at night
Old May 17, 2009 | 07:59 PM
  #33
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Back from the dead.
This write-up was excellent. Thank-you.
I modified your directions slightly in the following way:
As you know, some JDM 92-95 Civics came stock with a maplight assembly. I believe these were exclusively the models with a sunroof, but I am not 100% sure. <- EDIT: Incorrect. Models with and without sunroof in combination with a map light exist, though the style of map light is different - large (oversize) one w/sunroof, narrow (small) one w/o.
Anyway, the part number on these JDM Civics was 34256-SR3-901ZB; this is the exact same part number used on the 2-dr CDM 98-00 Si / 99-00 SiR, 4-dr CDM 98-00 Acura EL, 2-dr USDM 98-00 EX / 99-00 Si and 4-dr USDM 98-00 EX. (Note: All vehicles with sunroofs.)
I wanted to stay as true to the original Civic design as possible, so I obtained this part from an Auto Salvage yard, including a very long pigtail. The donor vehicle was a 2-dr USDM 98-00 EX. Cost: $20 (a bit high, IMO)
After cutting the hole as instructed, I fed the long pigtail down to the A-pillar and connected it to the dome light WHT/RED wire with a T-Taps. I crimped terminal O-rings to the end of a 14ga BLK wire and bolted these in through the original mounting/grounding holes on the map light assembly with a small screw and nut. This was grounded with another terminal O-ring not at the sun visor mount like you did, but at the sun visor clip which is much closer. I also added a small washer between the O-ring and the headliner to make the connection more reliable.
I am extremely impressed with the amount of light cast by the unit and think this is a pretty useful modification.
Photos:
Last edited by deschlong; Sep 29, 2009 at 06:06 AM. Reason: New info on w/ and w/o sunroof map lights.
Old Jul 19, 2010 | 07:12 PM
  #34
funkyfreshpnoy's Avatar
Old Jul 20, 2010 | 11:02 AM
  #35
PSU's Avatar
PSU
formerly DxHatchback
Originally Posted by Harryflores
Nice write up and DIY
himsweet66six
Audio / Security / Video
Oct 5, 2010 05:28 PM
vvtli78k
Jun 30, 2008 06:24 PM
Hatch It
Jun 8, 2004 07:33 AM
preluder
May 18, 2003 07:34 PM
