SONEM EF bolt-in hydraulic clutch conversion
It's time. I emailed you's guys. Kit + high press line. Dang. Today's an expensive day. Just ordered a pair of seat brackets & rails for the Recaro setup. Feelin a lil poor now.
DA test fitment in progress. i'll know for sure by this weekend.
unlikely, but if failure occurs, we'll deal with it case by case. we stand by our customer service, we're not happy unless you're happy.
Originally Posted by I CRX I
would these come with any type of waranty?
i meant, in the case of unlikely failure, we'll deal with it case by case.
I ordered my bracket today. As long as everything else gets here on time I'm planning on doing the install this weekend. I'll try and snap a couple shots while the dash is off.
How long have you test this setup? I think the design is not strong enough. I think for daily driver this will break in less than a year. I really want hydraulic setup because I broke 4 bracket and 4 cable in 2 yrs. All from honda. I am planning to use wilwood floor pedal set up. But I don't know if there any space for the etu.
What all should I be looking for in the image above to complete my parts list?
Illust #'s: 006,008,009016,017,018,028,031 (x2)
Mind you I'll get a lot of little things from the junkyard, but this is just a reference guide.
Put some part numbers together to make it easier.. with pricing.. figure more info would get more people interested. all prices are from myhondapartsstore.com Anything else that you can add to this list to make it a complete install would help out... minus welding or labor charges.
BRACKET KIT---------------------------------------------------150.00
46164-632-000 FLOAT ------------------------------------------3.51
46920-SR3-A01 MASTER CYLINDER ASSY., CLUTCH ------------ 93.08
46928-SF1-000 SEAL, CLUTCH MASTER CYLINDER -------------- 3.51
46930-SR3-013 CYLINDER ASSY., SLAVE -----------------------54.56
46966-SR3-A00 HOLDER, TANK ----------------------------------8.40
46972-SD4-003 TANK, CLUTCH FLUID ----------------------------8.56
46973-SD4-003 CAP, RESERVE TANK ---------------------------- 13.83
46975-SD4-003 SEAL, RESERVE TANK ---------------------------- 2.98
94070-08080 NUT-WASHER (8MM)-------------------------------- .24 (x2)
95701-08025-08 BOLT, FLANGE (8X25) --------------------------- .68 (x2)
Line to connect everything ---------------------------------------$depends on what you want to use
Fluid--------------------------------------------------------------$$
TOTAL(just parts)-----------------------------------------------$340.27
