My Honda Beat Project - A technical deconstruction of a little known Honda.
Old Sep 19, 2008 | 11:13 AM
  #101
HitF8's Avatar
Default Re: (FamousRacingInk)
any updates?
Old Sep 26, 2008 | 03:32 PM
  #102
stunn'd's Avatar
Man I want a Beat hah. Soo cool.. Ill be watching this thread.
I remember seeing a Beat at Michener Allen awhile back, this wouldnt happen to be the same one would it?
Also, just curious, im around 6' tall as well, how high does your head stick up in relation to say the top of the windsheild? How much headroom do you have with the top up?
Old Sep 26, 2008 | 04:40 PM
  #103
tyr's Avatar
tyr
New User
Default Re: (stunn'd)
I'm just over 6 feet tall and I fit comfortably in a beat. Getting in and out can be slightly awkward especially with the top up, but once you're in it's fine top up or down. A couple of chunky friends of mine, one is 6'4", went for a drive in my beat and said it was ok for them.
Top down you're head is not sticking up above the windsheild, you sit very low in the car. I have too many cars so I might sell mine if you really want one.
Old Sep 28, 2008 | 11:48 AM
  #104
JOEY F.'s Avatar
Default Re: (tyr)
wow ... what a pleasant surprise this turned out to be. Ill be keeping up! Great work.
Old Oct 8, 2008 | 07:25 PM
  #105
nismogti-r's Avatar
Default Re: (WhiteSol)
Hi Sol
I've been a Beat owner for about 6 months now and I was wondering what you did with the original E07, if you still have it, I'd like to buy it for spares!
thanks, you can email me at hothybrids@hotmail.com
Nick
Old Oct 8, 2008 | 10:06 PM
  #106
CRX T-Si's Avatar
Default Re: (nismogti-r)
This is cool.
One thing I cannot figure out is the shift linkage.....
Makes me want to get one and slap a K in there....lol.
Old Oct 8, 2008 | 10:56 PM
  #107
WhiteSol's Avatar
Default Re: (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nismogti-r &raquo;</TD></TR><TR><TD CLASS="quote">Hi Sol
Nick</TD></TR></TABLE>
Expect an email shortly..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">This is cool.
The shift linkage is actually very simple problem to overcome. One cable controls the left and right movement of the stick shift, the other controls forward and back.. so really all you have to do is recreate the movement of a solid linkage by fabricating a mount for the cables, and a small linkage to attach to the gear selector..
Old Nov 2, 2008 | 07:24 PM
  #108
nismogti-r's Avatar
Hi whitesol
I'm still interested in whatever you got to sell of your beat, so email me if when you can or add me to MSN with my email listed higher on the thread!
thanks
Nick
Old Nov 6, 2008 | 07:52 AM
  #109
Theobeat's Avatar
Default Re: My Honda Beat Project - A technical deconstruction of a little known Honda. (mrlegoman)
Hi, I come from China
and here is my beat
I can't got a beat manual , i wanna connect the e manage to my beat by my self,
finally , i got the circuit here. Thx
Old Nov 6, 2008 | 08:15 AM
  #110
WhiteSol's Avatar
Default Re: My Honda Beat Project - A technical deconstruction of a little known Honda. (Theobeat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Theobeat &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I come from China
and here is my beat
That is awesome, glad to hear this thread has helped someone!
Please feel free to post a few more pictures of your Beat.
-Scott
Old Nov 16, 2008 | 12:32 AM
  #111
sfz2cover's Avatar
Default Re: My Honda Beat Project - A technical deconstruction of a little known Honda. (WhiteSol)
I need an air filter and the two door mirrors for my Beat. can anyone please help with finding parts. Where can one buy them from?
Old Nov 16, 2008 | 02:33 PM
  #112
WhiteSol's Avatar
Default Re: My Honda Beat Project - A technical deconstruction of a little known Honda. (sfz2cover)
I'm going to start importing some Beat parts, I'll post what I have for sale up on H-T when I get some stock.
Update time..
My neighbour is letting me use his garage for a few weeks so I can finish my suspension setup for the rear. I tried using my driveway, but it is not level enough to plumb-bob with any accuracy.
Mapping out the stock suspension points
32mm splined hub and LCA from a first gen Acura Integra (86-89)
Little somethin I picked up for the project..
Now the problem I have encountered is that the first gen teg knuckle uses a different diameter of strut than all other mac-strut Honda's. This would not problem except that there is no spring over the first gen strut. All of the spring loads come from what honda referred to as a "torque tube", essentially a spring loaded (think garage door spring) rod with an arm at the end that connects to the LCA - aka torsion bar suspension. So this means I have to find some tubing with the same inner diameter as a standard Honda macpherson strut, weld it on to the strut, and machine it to the 1st gen Integra strut ID.
The difference in strut outside diameters is quite small, 41.66mm for the 90-01 Teg and 45.08mm for the 86-89 = 3.42mm. It is enough however, that the strut would not fit securely into the knuckle.
86-89 Teg torsion bar suspension
The decision to use the first gen teg knuckles came after a failed attempt to use machined 32mm spline hub to fit the Beat knuckle. I decided because I could not replace the Beat bearing it was not a good idea, plus the fact I would have to machine the outer axle stubs to fit into the back side of beat knuckle. Too much machining, too many custom parts; I want to use as many OEM parts as possible with as little machining as possible.
Here are the pictures of that failed endeaver though..
Integra 32mm on the left, Beat 26mm on the right.
Machined to the same size OD within 0.0003"
Polished with 2000 grit
Cheers,
-Scott
Old Nov 16, 2008 | 08:24 PM
  #113
sfz2cover's Avatar
Great!!! Let me know as soon as u get em...btw, any chance of getting the mirrors...also, I might b in Tokyo for a day mid January 09, any Beat parts store or dealer?
Thanks 4 ur help.
Old Nov 21, 2008 | 10:03 AM
  #114
WhiteSol's Avatar
Fixed my thread index after the dreaded VB install.
Old Nov 21, 2008 | 11:02 AM
  #115
Riced-EL's Avatar
Sick build...
Old Nov 22, 2008 | 12:45 PM
  #116
RallySol's Avatar
Aaah, so this is what you've been up to! Very cool little ride, should move like stink when you're done =D
Old Nov 22, 2008 | 09:27 PM
  #117
bananaketchup's Avatar
this is a dope thread! heres another vid for ppl just tuning in
http://www.youtube.com/watch?v=MfFUWUR4zek
Old Nov 23, 2008 | 07:53 AM
  #118
Dazed and Confused's Avatar
Sick build. You better finish it. haha.
Old Nov 24, 2008 | 02:25 PM
  #119
thehatchninja's Avatar
very nice thread.
Old Nov 24, 2008 | 03:07 PM
  #120
Smokinsax's Avatar
The Boot
i dont think it will line up, because everyone has different options of the amount of post show up on one page.
Old Nov 25, 2008 | 12:24 PM
  #121
Blown90hatcH's Avatar
Nice build man. I just got back from Tokyo and these little guys were all over the place.
Old Dec 11, 2008 | 09:23 PM
  #122
clayton bigsby's Avatar
any updates on your build? cant wait to see it finished
Old Dec 11, 2008 | 11:09 PM
  #123
Ruben19's Avatar
crazy build
Old Feb 11, 2009 | 09:37 AM
  #124
markspan6243's Avatar
Flattery Will Get You Everywhere
lol dude do you have to make all of your cars outrageous? sweet build
Old Feb 11, 2009 | 06:39 PM
  #125
WhiteSol's Avatar
Updates are coming, just busy with school at the moment and trying to work on my Del Sol too. I'll hopefully have a chance to produce some parts for the Beat in the next few weeks. I have the rear suspension all drawn out, I just need to spend some time on a mill (or CNC) and make them.
I try.. I get bored easily and this is what I do to keep my interest in the car.. that and I see the potential from things that are easily underestimated.
-Scott
