15x8 rims in 5x114.3 where to buy new? What are you using?
Old Jul 23, 2008 | 07:22 AM
wildoutwhitegsr's Avatar
Default 15x8 rims in 5x114.3 where to buy new? What are you using?
I can't seem to find any 15x8 rims that are available to buy new other than the rota slips, but they have a 40offset and I was hoping for something a little bit lower around 36 or so. Unless someone can show me a pic of them on the car. More importantly then clearing the rear trailing arm.
What rims do you guys have in 15x8 & where did you buy them?
Old Jul 23, 2008 | 07:32 AM
get RIGHT's Avatar
Default Re: 15x8 rims in 5x114.3 where to buy new? What are you using? (wildoutwhitegsr)
Have you figured out a suitable tire chioce for this rim yet?
If so, what is it?
Old Jul 23, 2008 | 07:37 AM
Bradstard's Avatar
Jeep Wrangler wheels.
Modified by Bradstard at 11:48 AM 7/23/2008
Old Jul 23, 2008 | 08:00 AM
jgirard's Avatar
Default Re: 15x8 rims in 5x114.3 where to buy new? What are you using? (Bradstard)
Brad where were those at expo?
Old Jul 23, 2008 | 08:05 AM
eluam's Avatar
Default Re: 15x8 rims in 5x114.3 where to buy new? What are you using? (get RIGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">Have you figured out a suitable tire chioce for this rim yet?
If so, what is it?</TD></TR></TABLE>
My friend has 225/45 RS2's on his 15x8 K1s and they fit pretty good. A slight stretch, but the RS2s are pretty wide, almost a 235.
Old Jul 23, 2008 | 09:09 AM
Bradstard's Avatar
Default Re: 15x8 rims in 5x114.3 where to buy new? What are you using? (jgirard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgirard &raquo;</TD></TR><TR><TD CLASS="quote">Brad where were those at expo?</TD></TR></TABLE>
In the storage shed behind my house. I didn't want to do VIR on R comps.
Old Jul 23, 2008 | 10:21 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
damn! thats sick
Old Jul 23, 2008 | 11:01 AM
Dave_B's Avatar
Bah... those will rub if you drive hard enough on them.
Old Jul 23, 2008 | 11:11 AM
Bradstard's Avatar
Default Re: (Dave_B)
It's a good thing the only thing I do hard is park. New plate going on the R - HRDPRKR
Old Jul 23, 2008 | 11:22 AM
eluam's Avatar
Default Re: (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">It's a good thing the only thing I do hard is park. New plate going on the R - HRDPRKR </TD></TR></TABLE>
WHY DOES EVERYONE WANT TO STEAL MY PLATE!??!!?!?
Old Jul 23, 2008 | 12:50 PM
Aquafina's Avatar
trailing arm interference = notch it. There are a couple ways to do it.
Old Jul 23, 2008 | 01:03 PM
eluam's Avatar
Or lower offset, and pull the fenders, or flares.
Old Jul 23, 2008 | 01:08 PM
Aquafina's Avatar
I like aero better. I notched the arms on a local EW CRX for autocross so he could run 9" wheels. Bernardo Martinez (iirc) notched his arms his H1 Champ winning Integra running 9" wheels.
Old Jul 23, 2008 | 02:18 PM
ekim952522000's Avatar
Default Re: (Aquafina)
What offset is need so you don't have to notch the arms? 35mm?
Old Jul 23, 2008 | 02:23 PM
eluam's Avatar
Default Re: (ekim952522000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">What offset is need so you don't have to notch the arms? 35mm?</TD></TR></TABLE>
The Jeep wheels Bradstard has are 15x8 +20
Old Jul 23, 2008 | 03:23 PM
OMG that's wicked. Are you running any spacers to clear the front caliper since it looks as if the spoke design on the rim might be cutting it close.
get RIGHT I will soon be running NT01's in 225/45/15 if I can find a set in a warehouse.
eluam the ideal offset from the research black r did a while back is +24, but anything from +24 - +36 will work without you having to run spacers or notching the trailing arm.
Do any of you have pics of what a notched trailing arm looks like? How would you do this without reducing the integrity of the RTA?
Any pics of these cars running 9 inch wheels? More importantly specs on said wheels.
Old Jul 23, 2008 | 03:36 PM
Black R's Avatar
25 Year Member
i'll have info on fitment for 15x10 zero (or negative -1mm) soon if needed.
On a 15x8, the ideal offset is around +24 to retain the same clearance on the inside (backspacing) as stock.
Also, hoosier makes a 275/35/15 now.
Old Jul 24, 2008 | 07:10 PM
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">i'll have info on fitment for 15x10 zero (or negative -1mm) soon if needed.
Also, hoosier makes a 275/35/15 now. </TD></TR></TABLE>
Pls pls pls pls keep me informed. This sounds amazing
Old Jul 25, 2008 | 01:27 PM
ZygSpeed's Avatar
How do those 15x8 Rotas from the group buy fit on an ITR (and what size tires)?
Also, is there enough inner (diameter) spacing for Spoon calipers?
I have 5mm and 15mm spacers if needed (not for sale).
Old Jul 25, 2008 | 01:41 PM
Black R's Avatar
25 Year Member
Default Re: (Zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">How do those 15x8 Rotas from the group buy fit on an ITR (and what size tires)?
I have 5mm and 15mm spacers if needed (not for sale).</TD></TR></TABLE>
the 15x8 rota's kind of suck. they fit the same as the 15x7 version but have less backspacing. they will NOT clear spoon calipers without spacers.
Old Jul 25, 2008 | 01:44 PM
ZygSpeed's Avatar
Not a problem.
I've got 10 of them still in boxes at the moment.
I do need to roll the rear fender lips, though.
Old Jul 25, 2008 | 01:58 PM
get RIGHT's Avatar
LOL, Ed.
Old Jul 25, 2008 | 04:52 PM
ZygSpeed's Avatar
Default Re: (get RIGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">LOL, Ed. </TD></TR></TABLE>
I'd expect to hear that if I said I didn't have any wheelspin @ VIR, or even get into VTEC.
Which is pretty much true, ask Chad.
I was more worried about being able to stop (i.e., brakes), and had some ABS issues.
Modified by Zygspeed at 9:03 PM 7/25/2008
Old Jul 25, 2008 | 05:21 PM
get RIGHT's Avatar
After seeing your Beast close up. I believe ya.
bosted coupe
Dec 19, 2007 01:01 PM
H.
Feb 13, 2006 08:26 PM
professorman
Mar 23, 2005 11:25 AM
ek9800
Feb 20, 2005 02:04 AM
