Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
how much shorter RACE SPSS3
Old Dec 30, 2007 | 12:03 PM
Weel's Avatar
Default how much shorter RACE SPSS3
how much shorter are race koni spss3, compared to normal koni yellows?
1" shorter off the shaft and body? so total 2" of the whole shock
Old Dec 30, 2007 | 01:29 PM
solo-x's Avatar
Default Re: how much shorter RACE SPSS3 (Weel)
Fronts are 25mm shorter, rears are 15mm(?) shorter. Not sure on the droop limiter change, though I can't imagine longer droop limiters being used. Most of us don't care about droop limiter length as the rates we run are so stiff the shock has more droop range then the spring does. For your car, you might want to give Koni a ring and find out. Topping a shock out is as bad for grip as bottoming the shock out.
Old Dec 31, 2007 | 11:30 AM
STN_Pat's Avatar
Default Re: how much shorter RACE SPSS3 (solo-x)
front body 25mm shorter, 40mm more droop
rear body 15mm shorter, 35mm more droop
all of this avalaible on koni website
I got a honda
Suspension & Brakes
Apr 10, 2008 01:54 PM
pos_cd5
Mar 29, 2007 01:12 AM
bojangs
34
Apr 28, 2003 11:08 AM
bearboy80
Apr 17, 2003 01:58 PM
00VTEC
Oct 26, 2001 08:41 AM
