Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets?
Old Feb 21, 2006 | 10:07 PM
jeremy.'s Avatar
Default Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets?
does anyone have comparsion numbers or sheets of any of these cams on 12.1 compression? this would be on a 85mm bore, stock stroke ITR block. thanks in advance.
Old Feb 21, 2006 | 11:19 PM
UncleD's Avatar
Default Re: Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets? (ekay_jeremy)
Both Jun 3's, but hope this helps.
https://honda-tech.com/zerothread?id=1415895
https://honda-tech.com/zerothread?id=1499346
With M22x's in it: (284/12.1 - 284/12.1)
https://honda-tech.com/zerothread?id=1518936
Old Feb 21, 2006 | 11:48 PM
jeremy.'s Avatar
Default Re: Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets? (clean rice)
thanks for the links.....does anyone have any sheets or links to threads with any of the cams dyno'ed/baselined on the same motor?
Old Feb 22, 2006 | 12:00 AM
rodimus's Avatar
i'm gonna go out on a limb and say the Toda C's will net the most overall power.
i'm pretty sure the buddy club 4's have the same vtec lobe as the Toda C's...not sure about the primaries.
as for comparison sheets..don't have any
just thought i'd share. k bye.
Old Feb 22, 2006 | 12:09 AM
UncleD's Avatar
Default Re: Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets? (EVOL)
BC4/S2S2/Jun3 all have same vtec lobe. Toda C's are 300/12.5
Old Feb 22, 2006 | 12:16 AM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">BC4/S2S2/Jun3 all have same vtec lobe. Toda C's are 300/12.5</TD></TR></TABLE>
oh yahhh ur right..silly me, didn't we argue over that once?
Old Feb 22, 2006 | 08:16 AM
UncleD's Avatar
It was something like that, I can't really remember. Are you doing a K in your car man??
Old Feb 22, 2006 | 08:35 AM
GUILOTINE's Avatar
Kill Gil
you are correct but also please note the smaller duration they ahve though
Toda Spec C 12.5 mm, duration - 255 @ 1mm 12.5 mm, duration - 255 @ 1mm
Jun Type 3 12.0 mm, duration - 265.3 @ 1mm 11.5 mm, duration - 265.3 @ 1mm
I say Jeremy go at least with the Spec IV's , but Id personally go with the V's
Buddy Club IV 12.3mm, duration 306@1mm 11.8mm, duration-302@1mm
Buddy Club V 12.8mm, duration 312@1mm 11.8mm, duartion- 306@1mm
Old Feb 22, 2006 | 09:05 AM
jeremy.'s Avatar
thanks guys...anyone have dyno sheets to compare?
Old Feb 22, 2006 | 11:13 AM
WhoisDan's Avatar
I might have an extra set of brand new Jun3's.
Old Feb 23, 2006 | 08:59 PM
jeremy.'s Avatar
Default Re: Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets? (WhoisDan)
Old Feb 23, 2006 | 10:45 PM
92TypeR's Avatar
FSAE
Default Re: Toda C, Buddy Club Spec IV, or JUN 3 cams on 12.1 compression sheets? (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">I say Jeremy go at least with the Spec IV's , but Id personally go with the V's</TD></TR></TABLE>
The BC5's will bleed off too much compression for a 12:1 motor. He will have a broader powerband, including more peak, if he went with the BC4's versus the BC5's.
I am running BC5's temporarily as a tester, and I have roughly 12.3:1 static, these cams are limited on my motor to just over 3degrees advanced/retard before there is piston to valve contact, the duration is so big it drastically limits the ability to tune out the overlap. Might as well start with a cam that will allow more adjustability, and is more appropriately sized for his compression.
https://honda-tech.com/zerothread?id=1523438
FastAllmotorLsVtec
Jun 7, 2005 05:12 AM
b20todaej6
15
Nov 9, 2004 08:29 PM
PowerHouse
Apr 5, 2004 11:40 PM
vtec94civic
Dec 15, 2003 07:37 PM
blazin
Jan 6, 2002 07:31 PM
