****ej1 with gsr swap blowing ecu fuse HELP!
Old Mar 12, 2012 | 09:59 PM
ej1allday's Avatar
Default ****ej1 with gsr swap blowing ecu fuse HELP!
okay, so to start out my throw out bearing went bad so i replaced it while my car was running fine, then put it all back together and then drove down the road not but two blocks hit about 4 grand and it died, tryed cranking over but would budge, looked at it and the ecu fuse was blown, put a new one it and turned the car to the start position (didnt try starting it) and it blows the ecu fuse, ive been threw around 30 fuses trying to pinpoint whats making it blow we undid the whole engine harness and it dont blow, so its nothing in the interier then we plug in the engine harness and and disconnect everthing except the thermostat ground and it blows it. ive already tryed using a different motor harness and it still blows. please help asap thanks
lolv8s
Jun 24, 2019 10:20 AM
DC2GSR808
May 6, 2015 09:34 PM
DB2NineDuece
Jul 24, 2008 04:20 PM
b18BoostedDC2
Jan 21, 2007 11:13 PM
