Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
RACINGBRAKE EDP Coated Rotors!
Old 10-20-2004, 08:18 AM
MrHeeltoe's Avatar
Default RACINGBRAKE EDP Coated Rotors!
HP rotors from Racingbrake are now available from Heeltoe Automotive!
These rotors are designed IN HOUSE by Racingbrake here in the USA! Highly superior to Powerslot, Brembo, factory Honda, junk Chinese, and more, they are made of a specially engineered G3000 Iron Alloy for superior stregth, hardness (wear resistance), and heat capacity (prevent cracking and warping). These OEM replacement rotors also feature a highly durable black EDP coating on all surfaces, including inside the rotor, the outer ring, and inside the slots and drill holes!!! NO MORE NASTY RUST!
Here is an image of a RB HP Rotor, drilled and slotted
Here is a detailed pic of a UP Rotor (not available for most Hondas), which is a slightly different material and spec than the HP, but visually the same:
Racingbrake Front and Rear HP Rotors are available for these cars!
88-04 Accords
88-03 Civics
All del Sols
All CRX
88-01 Preludes
All S2000
90-01 Integra and Type-R
All RSX and RSX-S
All CL, TL, RL, and TSX
All Legends
MDX
NSX
Introductory sale price on these rotors is free shipping and no handling/transaction fees, A $40-50 dollar value!
Some Retail Pricing (prices are for each rotor)!
Integra 90-01
Front = $88.00
Rear = $63.00
Integra Type-R
Front = $114.00 (compare to Mugen, $152 each)
Rear = $88.00 (compare to Mugen, $135 each)
99-00 Civic Si
Front = $88.00
Rear = $63.00
92-95 Civic Si
Front = $88.00
Rear = $63.00
92-96 Prelude VTEC
Front = $130
Rear = $74
RSX-S
front = $110
rear = $88
RSX
front = $105
rear = $88
You saw them here first! These rotors, for the SERIOUS ENTHUSIAST, are a must have item!
Marcus
Some of you have been asking about 11.1" rotors with a 4x100 pattern. I can't get the 11.1" rotors from Racingbrake, but I CAN get them from another vendor of mine!
We can get 11.1" rotors with a 64mm center bore for Integras and EX civics, or in 61mm for all other civics! Similar technology is used in making these rotors as the Racingbrake ones. Engineered alloys and EDP coating makes them superior to everything else out there!
These rotors have the 4x100 bolt pattern manufactured in! These are not redrills they are specific rotors for this custom application!
Retail on these rotors is $132 each. Through a special deal on here, we can do $124 shipped each.
The rotors are drilled and slotted, just like the HP rotors sold by Racingbrake.
Modified by MrHeeltoe at 8:05 AM 11/17/2004
MrHeeltoe is offline
Old 10-21-2004, 06:09 AM
MrHeeltoe's Avatar
Default Re: RACINGBRAKE EDP Coated Rotors! (MrHeeltoe)
We can offer combos with Hawk Pads as well!
Old 10-21-2004, 10:37 AM
rastropovitch
Guest
Posts: n/a
Do they have a wilwood brake kit rotor replacement? it's a hat rotor set up in 12.19"
thanks
schu
Old 10-21-2004, 11:49 AM
Resident Evo's Avatar
Default Re: RACINGBRAKE EDP Coated Rotors! (MSchu)
Can I get a price for 92-96 Prelude VTEC rotors. Thanks in advance
Resident Evo is offline
Old 10-21-2004, 01:11 PM
MrHeeltoe's Avatar
Default Re: RACINGBRAKE EDP Coated Rotors! (EBP-Si)
Sure thing man....
92-96 Prelude VTEC
Front = $130
Rear = $74
Old 10-25-2004, 06:57 AM
t o m's Avatar
wow bump for some awesome rotors and an awesome seller. how much for RSX type S ones marcus?
t o m is offline
Old 10-25-2004, 09:26 AM
MrHeeltoe's Avatar
Default Re: RACINGBRAKE EDP Coated Rotors! (integra type s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra type s &raquo;</TD></TR><TR><TD CLASS="quote">wow bump for some awesome rotors and an awesome seller. how much for RSX type S ones marcus?</TD></TR></TABLE>
RSX-S
front = $110
rear = $88
RSX
front = $105
rear = $88
Old 11-01-2004, 07:43 AM
MrHeeltoe's Avatar
These rotors are sick...highest quality available!
Old 11-01-2004, 04:05 PM
Mikes01GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">Do they have a wilwood brake kit rotor replacement? it's a hat rotor set up in 12.19"
thanks
schu</TD></TR></TABLE>
Hey marcus what was the answer to this?
Mikes01GSR is offline
Old 11-01-2004, 06:06 PM
MrHeeltoe's Avatar
Default Re: RACINGBRAKE EDP Coated Rotors! (Mikes01GSR)
oh, the answer was regretably "No."
Old 11-03-2004, 09:08 AM
Mikes01GSR's Avatar
Marcus price for the legend rotors 11" x28mm anyway they could redrill a set
to 4x100?
Old 11-03-2004, 09:55 AM
HLee628's Avatar
correct me if im wrong, are these oem size?
HLee628 is offline
Old 11-03-2004, 10:25 AM
MrHeeltoe's Avatar
Default Re: RACINGBRAKE EDP Coated Rotors! (99accordexv6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99accordexv6 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong, are these oem size?</TD></TR></TABLE>
Yeah, OEM size...upgraded material and casting though.
Old 11-03-2004, 10:29 AM
MrHeeltoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR &raquo;</TD></TR><TR><TD CLASS="quote">Marcus price for the legend rotors 11" x28mm anyway they could redrill a set
to 4x100?</TD></TR></TABLE>
I sent off an email....they are in SEMA now, so the reply will take a little time....thanks for the question!
Marcus
Old 11-03-2004, 10:33 AM
AMV6's Avatar
MrHeeltoe,
Could you give me a price for rotors (front & rear) for an 04 Accord Sedan V6? Thanks.
AMV6 is offline
Old 11-03-2004, 06:14 PM
HLee628's Avatar
Default Re: RACINGBRAKE EDP Coated Rotors! (AMV6)
could i get a quote on a 1999 accord v6 coupe?
HLee628 is offline
Old 11-03-2004, 06:48 PM
Mikes01GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrHeeltoe &raquo;</TD></TR><TR><TD CLASS="quote">
Marcus</TD></TR></TABLE>
Cool thanks Marcus, incase you wondering this would help all of those integra
and civic people doing a legend/nsx caliper upgrade. Let me know when you
hear.
Old 11-03-2004, 08:50 PM
and civic people doing a legend/nsx caliper upgrade.</TD></TR></TABLE>
Same here. I was planning on saving up for racingbrake prelude rotors and have them re-drilled.
Is there any way I can get the prelude rotors drilled 4x100? Don't mind payin extra.
Old 11-04-2004, 06:42 AM
MrHeeltoe's Avatar
I will check on that guys...not sure if redrilling is a higher cost or not....but i will certainly investigate!
Racingbrake has a lot of technical knowledge and have been very responsive to my questions. Once they get back from SEMA, we will tackle this.
Old 11-04-2004, 01:05 PM
Mikes01GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrHeeltoe &raquo;</TD></TR><TR><TD CLASS="quote">I will check on that guys...not sure if redrilling is a higher cost or not....but i will certainly investigate!
Racingbrake has a lot of technical knowledge and have been very responsive to my questions. Once they get back from SEMA, we will tackle this.</TD></TR></TABLE>
Well I'm hoping the won't have to "redrill" maybe they can take a legend rotor
and drill it from the start as a 4x100 as a special order or something....Anyways
thanks for checking on it Marcus.
Old 11-04-2004, 06:37 PM
thanks for checking on it Marcus. </TD></TR></TABLE>
exactly what I was thinking. Havings the rotors drilled 4x100 by default
Old 11-04-2004, 06:46 PM
codenamezero's Avatar
do they come in some custom bolt pattern?
like 4x100 11.1" (ITR size)?
cos i am planning to do 2 pot caliper conversion, if these comes in 4x100 i'd be interested!
codenamezero is offline
Old 11-04-2004, 11:26 PM
Airbag Club's Avatar
i need the EXACT same thing as "Mikes01GSR." Let me also know when you find out the information. Thanks.
Airbag Club is offline
Old 11-05-2004, 06:56 AM
MrHeeltoe's Avatar
Ok, well.....I will see.....
Old 11-05-2004, 06:58 AM
yea let us know, i am interested on 4x100 legend/itr rotor as well.
but i don't want drilled, just slotted.
Quick Reply: RACINGBRAKE EDP Coated Rotors!
