Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Digital Torque Wrench Special
Old 10-28-2013, 02:13 PM
blmw's Avatar
Default Digital Torque Wrench Special
Get a jump on your Holiday Shopping and get our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: HT
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until December 31st, and is only for the lower 48 states.
Old 11-03-2013, 07:47 AM
blmw's Avatar
Default Re: Digital Torque Wrench Special
Don't need a torque wrench? How about a Digital Angle Gauge!!
It is a small unit that quickly and easily attaches to the shaft of any standard ratchet, wrench, or breaker bar and measures angular rotation for Torque-to-Yield / Torque Turn fasteners. You can read more about it here:
Professional Grade Digital Angle Gauge | Brown Line Metalworks, LLC
It was recently named by Motor Magazine as one of the Top 20 Tools of 2013. You can read the whole article here:
Motor Magazine Top 20
You can purchase it online at:
Toolsource and Sears
BLMW
Old 11-30-2013, 05:49 PM
SPOOLINmatt's Avatar
these look like a nice piece!
Old 12-19-2013, 07:22 AM
blmw's Avatar
Bump for a great torque wrench at a great price!!
Old 12-28-2013, 06:13 PM
blmw's Avatar
3 days left! Get yourself a great torque wrench.
Old 12-31-2013, 09:54 AM
blmw's Avatar
Get yourself a great torque wrench! Today is the last day!!!
blmw
Performance
03-29-2014 11:00 AM
blmw
01-06-2014 05:38 AM
blmw
12-31-2013 09:54 AM
blmw
14
10-15-2011 06:58 PM
blmw
10-15-2011 02:52 PM
Quick Reply: Digital Torque Wrench Special
