BUDDY CLUB N+ SPEC DAMPER NEW!!
BUDDY CLUB N+ SPEC DAMPER NEW!! SUPER LOW PRICING!!!
Fresh off the boat!!!!
Applications Available:
DC2
EG
EK
[ 1. Ride-Height Adjustable ]
Vehicle ride height is adjusted independently of spring pre-load. With other alternatives available on the market today, vehicle ride height is adjusted by reducing or increasing the preload on the coil spring. This primitive methold leads to inconsistent spring rates that are dependent upon the vehicle ride height. With any of the Buddy Club suspension components, including the N+ SPEC, vehicle ride height is independent of spring pre-load. This method ensures that the spring rate is always consistent, no matter how high or low your car is. In addition, it ensures that the spring is always properly positioned onto the strut and effectively reduces miscellaneous and unnecessary noise.
[ 2. 15 Level Adjustment ]
Suspension adjustability is a key element when selecting a top quality coil-over system. The N+ SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).
[ 3. Mono-Tube type shell case ]
The shock-body is constructed out of cadmium plated steel and is finished with beautifully anodized precision CNC machined aluminum ends. Urethane bushings are used when applicable to ensure a top quality product.
[ 4. Exclusive Buddy Club Springs ]
In a complete suspension setup, the coil-spring is a very key element. The coil-springs used on all Buddy Club suspension setups are specially made to exacting specifications by Buddy Club engineers. Each coil spring is manufactured to exacting tolerances to ensure performance in every demanding situation.
[ 5. Beautifully Finished ]
To ensure that the N+ SPEC Dampers stay looking superb through your years and years of ownership, each precision CNC machined aluminum component is beautifully burgundy anodized and each steel component is cadmium plated for corrosion resistance. Great attention to detail was taken to ensure that you will be completely satisfied with your ownership of Buddy Club components.
Please PM or call 1-866-238-1947 for pricing....
Modified by ImageInMotion.com at 5:04 PM 7/27/2005
DC2
EG
EK
Re: BUDDY CLUB N+ SPEC DAMPER NEW!! SUPER LOW PRICING!!! (ImageInMotion.com)
Whoa! Those are sweet!!
Are these better than the previous Buddy Club coilovers?
they are still keeping the previous design, these are buddy club quality at a wicked price!!!!
kinda following the ksport, omni, d2 trend.........
really good prices on these guys.... please pm or call in! thanks!!!
Re: (nggrmxn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nggrmxn »</TD></TR><TR><TD CLASS="quote">Yes Sir... Buddy Club is JDM!</TD></TR></TABLE>
the ones before were manufactured in Taiwan... just tryin to see if it's in the same boat as this one
Re: (ECAhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch »</TD></TR><TR><TD CLASS="quote">
the ones before were manufactured in Taiwan... just tryin to see if it's in the same boat as this one </TD></TR></TABLE>
Haha~~!!
Haha~~!!
passwordjdm
16
08-01-2005 11:30 AM
