** Ultra Rare BBS RE830 4x100 Drag Wheels...13x8, 13x9, 13x10, 15x3.5 **
Email -- James@IPGParts.com
Phone -- 407-324-4684
We have 7 pairs of the 15x3.5 skinnies left in stock
We have enough 4x100 centers left to make 10 more pairs of 13" front wheels.
Price are for Wheels only -- Tires can be packaged with them for additional money.
15x3.5 Skinnies are $1200/pair
13x8, 4x100 are $798/pair
13x9, 4x100 are $830/pair
13x10, 4x100 are $848/pair
We have (1) Pair of 15x3.5 Skinnies with M&H Tires already mounted on them for $1500/pair
Once what we have is gone they are gone for good as Brand New Wheels as BBS is no longer in production of these.
We have a very limited # of these available.
With all of our test fitting we have only been able to verify that these will fit a civic spindle setup (small brake setup) with the use of a 10mm spacer for caliper clearance. We have been unable to fit them on an Integra Spindle car (but if you want to try and your own feel free). The issue isn’t the backspacing it is the way the back of the face of the 4×100 center is designed, it is very flat and it needs to be pushed off the caliper (with the use of a spacer) to get the caliper clearance required to work. You may be able to use them on an Integra Spindle with enough spacer size used but we have tested up to a 15mm size and have not successfully fitted them. Also will require the use of extended wheel studs.
All the 15×3.5 wheels and 4×100 centers are physically in our possession at IPG. BBS America has some of the inner and outer barrels we need to complete wheels, these parts will be ordered in as we take orders and the 13″ wheels will be built then. Note, BBS America does not physically have enough parts on hand to handle all 13 pairs of fronts that we have but they have already checked with Germany for us and the parts are either in stock there or in production so some customers may see about a 3 week wait time before the 13″ wheels can be shipped. We will tell you as you place the order what you can expect.
