Semi Slicks on Turbo Daily?
Whats up fellas, I'm thinking about picking up Falkein Azenis but been having some mixed feedback. I live in New York and hearing the winter will ruin them, they'll only last 5k miles, terrible in rain. I currently have Kumho Ecsta and they spin to easily. I was only looking on just having the front two tires azenis or is that stupid since my back wheels have a ton of thread on them.
Re: Semi Slicks on Turbo Daily?
If you do end up doing that, do not try to run them in the winter. You will have zero traction on a semi slick in snow or ice, and even if it's dry and below 40 degrees F, you won't have much traction. You also run the risk of cracking the rubber if you drive summer tires in extreme cold conditions, regardless of road conditions.
The wet traction and hydroplaning resistance on semi slicks is very, very low in most cases, so if you want to run those on the front when it's dry and warm, you'll be in good shape, although we generally recommend using the same tire on all 4 corners. Any inclement weather will have you driving at significantly reduced speeds to retain control of the vehicle.
Depending on the weight of your right foot, 5k miles might not be too far off.
Have you looked into Toyo R888 I was considering going with those tires before I went with track setup on my car, so I no longer daily it.
This is definitely true for streetability, I don't recommend the R888s for a DD. That's a track tire. The Direzza ZIIs are what I run on my EP3 for street and autocross.
How many miles have you had the direzza for? And the traction with them? Do you notice a big difference from other tires?
Moderator
Of course there's a difference. that's why I recommended them. I've had several of these series of tyres including your Kuhmo Ecstas for years.
I don't log miles, really, as my dash doesn't utilize an odometer. But I'll say they'll do just fine for one that has over 530whp available on a turbo Integra, for the last couple of years.
thewrai6th
05-24-2011 07:07 PM
95civiccoupe31
10
07-24-2002 05:39 PM
