Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Wheel and Tire (https://honda-tech.com/forums/wheel-tire-56/)
-   -   replacing pads (https://honda-tech.com/forums/wheel-tire-56/replacing-pads-1716058/)
hamadiscool Aug 8, 2006 06:35 PM
replacing pads
hi i changed my dad's front right brake pads but accidently unscrewed the cylinder all the way and got some air in there. So now i changed the front left pad also and tried to bleed the two front brakes. When the engine is off the brake padel is really hard but when u turn on the engine, there is alot of travel in the brake padel before the brakes actually work. So my question is since the car has ABS do i also have to bleed the rear brakes (they are drums and not disks) ?? Or did i have to bleed the brakes while the engine was on since its ABS? any help is appreaited thanks
By the way, before i changed the pads there was no travel in the brake padel, the brakes were applied almost instantly THANKS!!
Leo C Aug 8, 2006 06:45 PM
Re: replacing pads (hamadiscool)
Bleed the brakes. You might need to do it a couple times to get the air bubbles out of the system.
hamadiscool Aug 8, 2006 06:52 PM
Re: replacing pads (shutupnskate)
but but but...i did, and when my dad was holding and releasing the brakes in the bleeding process, the brake padel got harder and harder but when u turn the engine on the pedal almost sinks back in https://honda-tech.com/forums/images/smilies/emsad.gif me no get it
nsxtasy Aug 8, 2006 08:52 PM
This forum is for wheels and tires. Not brakes.
Ask in the forum for your dad's car model (Civic forum, Integra forum, etc).
hamadiscool Aug 8, 2006 09:11 PM
Re: replacing pads (nsxtasy)
his car is a nissan sentra https://honda-tech.com/forums/images...s/emsmilep.gif and i didnt know where to go and ask https://honda-tech.com/forums/images/smilies/emsad.gif sorry but thanks for ur input
nsxtasy Aug 9, 2006 07:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool &raquo;</TD></TR><TR><TD CLASS="quote">his car is a nissan sentra https://honda-tech.com/forums/images...s/emsmilep.gif and i didnt know where to go and ask</TD></TR></TABLE>
http://www.sentra.net
