Rays valve stem install
I just picked up a set of rays valve stems for my Volvo aluminum wheels and wanted to know the correct way to install them.
Is this the correct way to install them? Stem - rubber seal - wheel - flat washer - thick nut (nut side up) - lock nut - valve cap. What torque spec should I use? Lock the two nuts together? Thanks https://honda-tech.com/forums/images/smilies/emthup.gif Will https://honda-tech.com/forums/images...es/emdgust.gif |
Re: Rays valve stem install (Willard)
Mine have a rubber seal on both sides of the stem.
Be careful not to over tighten or marr the finish. I would not worry about using a torque wrench. Just tighten the first nut until you can see the rubber washers start to crush. Put a dot of lock tight on the threads where the lock nut will rest. With a wrench on both nuts tighten the lock nut until you have reached the same amount of torque required for the first nut. Maybe a smudge more. You should be good to go. It's not rocket science. https://honda-tech.com/forums/images/smilies/emthup.gif Also pay attentin to what you are doing. What may feel like the nut tighting up could be the wrench digging into your rim. If you don't know what I am talking about you will when it happens. |
i think this is the order. this is not a rays valve stem but the principle is similar.
http://www.kurveygirl.com/ebayphotos...0Seperated.jpg |
| All times are GMT -8. The time now is 12:20 PM. |
