konig rollers
i was wondering if the rivets can be removed ?
Re: konig rollers
Originally Posted by wstmsol
(Post 46129638)
Re: konig rollers
Originally Posted by toyomatt84
(Post 46129908)
They're just plastic that is glued/pressed in. If you can remove them without breaking them, then you may be able to re-install them.
Re: konig rollers
I wonder if you can drill them out then put actual bolts in like in that link... I like the rollers also
Re: konig rollers
Originally Posted by jserman
(Post 46130018)
Re: konig rollers
(Post 46130077)
yeah thats what i want to do :D
Re: konig rollers
(Post 46130081)
do it and let me know how it turns out... Do you have rollers now???
Re: konig rollers
(Post 46129953)
what tool ? and could you replace them with other rivets? like these http://www.nlmotoring.com/product-p/kithd46004.htm possible to try ?
Those bolts (not rivets) should work fine, if you're willing to drill through the wheel's face to mount them properly. I'd make sure to use the proper sized drill bit, though (which would require having the hardware kit on hand). |
Re: konig rollers
(Post 46131322)
To be honest, there's not a special tool that removes those carefully. You'll have to just be creative when removing them, if you want to keep them from being damaged.
(Post 46129908)
(Post 46129638)
Re: konig rollers
From what I've seen, they're almost always plastic. But, I haven't seen every one out there.
Re: konig rollers
Re: konig rollers
Another place you can check for replacement rivets is www.prestigewheel.com. They tell you how to measure them properly and I think they average around .50-.75 cents each.
| All times are GMT -8. The time now is 11:51 PM. |
