Does anyone change wheels in winter?
Old 10-20-2018, 08:59 AM
Slow&Steady's Avatar
Default Does anyone change wheels in winter?
My Accord has the OEM 8 spoke alloy wheels but those are looking rough. I am about to have them powder coated in a 2-tone scheme. I have found a set of OEM steel wheels of the same size from a wrecked Accord.
My plan is to run all season on the alloy wheels in spring, summer, and fall and winter/snow tires in the winter on the steel wheels. I'll do a wheel/tire swap as winter and spring approaches.
Anyone else do this?
Old 11-10-2018, 01:01 PM
thisguyaves's Avatar
Default Re: Does anyone change wheels in winter?
Tons of people do this. I plan on similar setups this coming winter
Old 12-06-2018, 12:56 AM
TDFbound's Avatar
Yes, a second set of wheels and tires for the winter is a great idea. I do this on each of my cars! For my new Civic, I'll be getting a second set of alloys though, as the salt from winter roads can rust the steel wheels. A proper snow tire makes a BIG difference versus an all-season tire.
Old 12-08-2018, 05:00 PM
Alloy wheels corrode too.......as I have found first-hand plus they stick to the steel rotors and drums, "dissimilar metal corrosion." I plan to have my alloy wheels powder coated this coming spring.
How about that big snow and ice you guys in NC got coming?
Change of plans: I no longer will get snow tires for this winter as I'm parking my Accord until spring for when I get those brake and fuel lines remade and replaced (doing it myself). Next year though, I definitely want to go through with my original plan to run all seasons spring, summer, and fall, and winter tires in winter.
Good luck on getting a second set of alloys.....are you buying new, hitting up a junkyard, or buying period remanufactured?
Old 03-01-2019, 01:03 PM
Alex98's Avatar
I did this when I had my Civic. I rolled my fancy 15" wheels from about May to November, and then 13" steelies in the "off" season.
gnaff9093
Acura TSX
03-01-2015 09:45 PM
oblivion2kx
10-15-2007 09:17 PM
mkazm83
08-20-2005 08:19 AM
ESCALVANTE
14
04-29-2002 05:29 PM
Quick Reply: Does anyone change wheels in winter?
