Air leaking at clip-on wheel weight: can I replace with adhesive weight at home?
Or do I need to take it to a shop to have them rebalance the tire with adhesive weights?
Sanji
Re: Air leaking at clip-on wheel weight: can I replace with adhesive weight at home?
If air is leaking at that point, you'll need to clean the mounting surface. If you can dismount the tire at home, clean the barrel, then remount the tire and balance it at home... then you should be fine.
Assuming that taking the clip on weight off will stop the leak, my question is can i put an adhesive weight on the same area but inside the rim or does it require precision of using a tire balancing machine.
The leak is because of corrosion on the rim flange/ where the tire bead seats and is supposed to seal your tire. It may be pushed back slightly by a hammer on weight but it's leaking because of corrosion. Go to a tire shop and ask for a re-seal and re-balance. If you don't have a tire machine and a balancer, no you can not fix this at home. Make sure they use a quality 'bead sealer' after grinding/cleaning your rim flanges otherwise it'll corrode again sooner and do it all over again.
The clip on weight alone won't cause a leak, as otherwise all cars would have leaked air like no tomorrow. You have a different problem and it is just a coincidence that it is leaking at the weight. Unless of course someone put a truck weight on your car. Go to a shop as this is not the type of work one easily DIY in the driveway.
